Question about Canon S400 InkJet Printer
Flashing my canon s400 is flashing orange three time - lost the manual so don't know what it means - thanks for any help
  • Anonymous Nov 28, 2008
    same deal
  • Kendall Fairburn Mar 29, 2009
    Same problem. The yellow light blinks three times. Won't print. Thanks, Kendall
Help me plz
Posted on Oct 13, 2008
My is not working & shows an error code B200.
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 25, 2010 | Canon Office Equipment & Supplies
My printer is blinking orange lite
Hi there ok try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 18, 2009 | Canon S400 InkJet Printer
6 orange and 1 green flashing light on S400 canon bubblejet
Friend your printer has reached to its printing limit. Its printer has a maximum of printing point it is registered in the printer memory. When it reach to its limit it will stop. To solve this problem you need to use CSS Utility Software so that you can make the printer reset then you can print again. You can download for just type CSSutility software in google or yahoo. then download.
Apr 09, 2009 | Office Equipment & Supplies
Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Feb 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip1300. Three orange flashes, one green.
Hi emdos,
Did you mean blinking three times in Orange?. Well, the problem is paper jam error occurs in your printer. First, check if any broken paper inside printer. If it so, remove broken paper. If problem still persist, it seems that drive assy broken or paper feed sensor fault. Find more useful article about this below.
Soruce:
Canon Inkjet Printer Forum
Nov 26, 2008 | Office Equipment & Supplies
Printer Blinker
I am a Dell Certified System Engnieer(DCSE).
open control panel
click on printer option go to printer properties
you have to locate an option which says alignment
and there is an option for head cleaner just run these two options and let me know what happened.
Jun 09, 2008 | Canon BJC S400 / CanoScan N650U InkJet...
Printer
How many times it flashes?. It flashes in Orange or alternately in Orange/Green. This flashing LED has certain count that indicates the error occurs in the printer. To find out how to identify error indicated by flashing LED, please check here ;under article How to identify error indicator. Please tell me soon after knowing how many times the printer LED flashing.
Regards,
Jan 04, 2008 | Canon S400 InkJet Printer
Need help with S-400 Canon
How many times from pause to pause?
May 13, 2007 | Canon S400 InkJet Printer
Canon S400 InkJet Printer Logo
247 people viewed this question
old marine
old marine
Corne Viljoen
