Question about Epson STYLUS CX3900 All-In-One InkJet Printer
Poor print quality, not fully black with white lines through text/images.
    Brigadier General:
  • 10,406 Answers
The white lines are caused by some CLOGGED ink-jets that are not spraying the ink onto the paper at the appropriate time.
Start the Epson printer-software, and run a "print-head-cleaning-cycle", to try to UNCLOG those ink-jets.
Posted on Oct 17, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Lexmark ms410dn printing poorly
Did you shake the toner cartridge before installing in the printer? Sometimes the toner will clump in the cartridge due to shipping etc., and needs to be shaken to loosen it up.
Aug 07, 2014 | Lexmark MS410dn Monochrome Laser Printer...
Poor print quality of images on envelopes
clean the print head 3 times,then realign the head .these are done by printer utility software given with the printer.
Even not ok.
Then Replace the New Catridge.(manufactured from within 3 of 4 months).because the ink will be dried with in 6 month.So Buy Carefully with Mfd Date.
Thank you
Feb 13, 2010 | HP LaserJet 4650 Color Printer
Samsung CLP-300 poor print quality
black developer on drum worned out,need changing.
May 05, 2009 | Samsung CLP 300 Laser Printer
HP officejet 7210 hortizontal white lines
I would suggest you get a set of original HP cartridges .. I have clients trying to save $ all the time by buying refilled and/or refilling themselves to only go and get HP brand. Refills just don't cut it .. leaks, poor print quality, unrecognized cartridges .. there are so many things that I can point out .. save yourself the hassles .. get HP
Mar 30, 2009 | HP Officejet 7210 All-In-One InkJet...
Copy quality is poor. Replace toner, drum and transformer?
when you say the quality of the text is poor I am assuming that your are describing the line print
FIX
IF FUZZY remove corona wire and clean with q tip diped in alcohol
If IMAGE OFFSET check fuser rollers emove pad and ad fuser oil
IF copies lite remove print cartridge and shake back and forth to get toner distributed
also examine photoreceptor sounds the shutter is not closing and causing image distortment
Jan 05, 2009 | Sharp AL 1631 Copier
OKI c5400
Assuming that you are using the same paper and have not changed any of the consumables you should do the following:
1. Clean LED head with lens cleaner or soft tissue.
  1. Remove the toner cartridge and give it a few shakes then reinstall it.
  2. The Toner Could be low so Change toner cartridge.
4. Make sure that the paper is not damp as this will cause fading and poor quality printing and images.
  1. The image drum may have been light contaminated so remove it from the printer and store it in a totally dark place for several hours then reinstall it.
  2. If the image drum is dirty then wipe it very gently with soft tissues, being careful not to scratch it.
  3. Open the top cover and check to be sure that each toner cartridge is fully seated and that each toner cartridge lock lever is pushed all the way back.
  4. Press the top cover release latch and open, then close, the cover.
  5. Check MEDIA MENUTRAY1 MEDIA TYPE and set as required. Do the same for TRAY2 and MPT.
  6. Check MEDIA MENUTRAY1 MEDIA WEIGHT and set as required. Do the same for TRAY2 and MPT.
  7. Possibly set the value of media weight in the menu to the next heaviest one.
  8. Check PRINT MENURESOLUTION setting and set to 600 x 1200DPI
  9. Check PRINT MENUTONER SAVE MODE and make sure this is OFF
  10. Check PRINT MENU – MONO PRINT SPEED and make sure this is set to MIXED SPEED
  11. Check the COLOUR MENU – DENSITY CONTROL and set this to AUTO
  12. Check the COLOUR MENU – AUTO DENSITY and set this to EXECUTE
  13. Check the COLOUR MENUCMY 100% DENSITY is set to ENABLE if you want a glossier black finish.
Feb 17, 2008 | OKI C5400 Laser Printer
Epson STYLUS CX3900 All-In-One InkJet Printer Logo
166 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
