Question about HP Officejet 4110 All-In-One InkJet Printer
"Insert New Cartridge" Error Message
I just inserted a new black cartridge and the screen reads "Insert new cartridge". I've tried taking it out and putting it back in, but the message doesn't go away.
  • Sherryptk Jun 04, 2008
    I think the problem is with the printer. The message existed before I changed the cartridge and after I put a new one in, it didn't go away. Any suggestions on how I can fix the printer?
    Thanks
  • 61 Answers
Sorry for the dumb & obvious question but did you remove the protective tape from the cartridge before inserting it. If so, then try returning the cartridge for a new one, you may have gotten a bad one. If problem continues you may have a printer problem. Also, you could reinsert your old one and see if you get the same error or an out of ink error. If you get an out of ink error the problem is most likely with the new cartrideg...if you get same error, the problem is most likely with printer.
Good luck.
Posted on Jun 03, 2008
Black Cartriddge missing
Try taking out both cartridges from your printer. Re-brick your printer by pulling out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds. When the printer turns on, re-insert your color cartridge then close the cover. If no error appears, re-insert your black cartridge. If error still appears, then it could be a faulty cartridge. It would be best to replace it with a new cartridge, preferably a genuine one. Lexmark products work best when original supplies are used.
Dec 02, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have inserted a new black ink cartridge (34) and get an error message 'left cartridge missing, insert black or colour photo cartridge' have peeled label off and reinserted several times but still...
Make sure you are inserting a genuine Lexmark cartridge. Try to insert a different known working cartridge, maybe your old black cartridge, to determine if your new cartridge is faulty. If inserting your old black cartridge gives you a message saying "very low ink" or something to that effect, then most probably there's something wrong with the new black cartridge. Have it replaced with a new one from the store where you bought it from. You may also contact Lexmark Technical Support Center for assistance.
Aug 12, 2011 | Lexmark X8350 All-In-One InkJet Printer
I have error 1200 on my lexmark x4270 fax machine after installing new black cartridge.
The 1200 error code indicates that the cartridge carrier has stalled. It could be due to the new black cartridge installed in the printer. Make sure you are using the correct version of black cartridge for your model and it's properly inserted in the cartridge carrier.
To remedy the problem, try to remove the black cartridge from the carrier > close the cover > unplug and re-plug the printer into the power source to reset it > when the printer turns on, re-insert the new black cartridge > check for any errors. If problem continues, try to insert a different known working black cartridge to determine if the new one is faulty.
For further troubleshooting, you may also refer to this article found in the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Jul 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
I tried replacing the printer toner-I get a message saying "Cartridge error. Put black toner cartridge back in"
Remove the "new" cartridge, and re-insert the "old" cartridge, to see if _only_ the "new" cartridge causes the error.
Otherwise, take the printer to a qualified technician.
Jan 23, 2010 | Brother MFC 7840W Printer
Error message insert black cartridge.
Just replace the black cartridge with new one.
Nov 05, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
My black cartridge was empty so I bought a new one. When I inserted the cartridge...the screen read "Remove and Check Cartridges." The "Copy", "Scan", and "Photo Card" tabs keep blinking as well....
hawleydn,
I know this might sound crazy, but your brand new cartridge is junk. Take it back and get a new one. I've done this several times with my HP PSC 2210. the all-in-ones are sometimes finicky with the cartridges. Also, be careful when you insert it into the slot. There is a small wire clip thing on the right side that is easily broken if you try to force it in.
If this helps, give me a vote :o)
samson39
Jul 25, 2009 | HP PSC 2175 All-In-One InkJet Printer
Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Jun 17, 2009 | Dell 926 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    Error check ink cartridge
    Hi ,
    As per the information provided by you it seems to be a hardware issue however u cvan try these steps .
    Steps >
    Take out the ink cartridges from the printer > without turning off the printer unplug the power cord > press # and 6 key together , now without releasing the keys plug in the power cord .
    keep on holding the keys down until the machine turns off automatically .
    after the unit turns on again it would do the allignment give a msg for insert ink cartridges . insert the cartridges at that time . and see how it works out .
    Thanks
    MAC.
    May 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    HP Officejet 4110 All-In-One InkJet Printer Logo
    89 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
