Question about Electronics - Others
Asa ka ron? - Electronics - Others
Unstable projector display
Ayo, Kumusta na ka kuya? Asa man mo i ate mayet karun? Emaili ko kuya asap....prestige_bands@me.com Gemma- tony
Jun 17, 2012 | Samsung Sp-m250s 3lcd Projector Hdtv Home...
Sir pl.i need manual internet settings for qmobile e900
salam yar mery QMobile E900 naya liya hai es ka tuch ky sath vibration hy ye kaisy hatam hojayi gi profil main to ring tone bi kia hy lekin pher bi koyi samaj nahi araha hy pora setap daiklia hy main
Thanks
sami
aur dosra masla ye araha hy ke es ko jab main lock karta hu to es ko jab main kolta hu to ye muj say inpute passward mangta hy pher es ko main bettri nekalta hu ato on hojata hy
plzzzzzzzzzzzz
Feb 26, 2011 | Cell Phones
How to export log from CISCOASA?like other cisco device logging 1.1.1.1 i want similar kind command in CISCO ASA
ASA's log is usualy stored localy on ASA itself, so easiest way to export that log is to go with telnet/ssh/console on it, do a command : show logging and copy/paste output into a new file.
but beware - this log is really short and as soon as ASA is rebooted - it's gone.
you could set asa to log to a syslog server (free on linux/freebsd or for windows use KIWI app).
that way all ASA log output is stored on pc/server running your syslog server.
Jan 03, 2011 | Cisco ASA 5510 Firewall
My cisco asa 5505 lost it image file ... how can i get the image back
if it is really deleted from FLASH, you will need to connect to ASA with a console cable, start up TFTP server on your pc, and in TFTP copy your ASA image file (.bin - on your CD that you got with ASA) so that you can get it from pc to asa.
then use tftpdnld command to set all the parameters on asa and start the download of the file from your pc .... after it has been done - just reboot asa :)
Dec 15, 2010 | Cisco ASA 5500 Firewall
Sir, hamari tv ka name thomson hai hamari tv
there is problem with your power supply.Must be fuse,capacitor,Str or FET are short or open.But care fully there is live voltages if you know that how to replaced then ok.
Oct 18, 2010 | Thomson LCDB 03B 27 in. Television
Hello all can you please help me on how to restore the configuration of my ASA 5520? thanx
If you are going for factory reset use the following commands
asa>enable
asa#write erase
asa#reload
Dont save the configuration when it prompts for it.
if you want to restore the configuration from the backup
1. You need to have a TFTP server
2. Locate the config file on your TFTP server
3. TFTP server should be reachable from ASA
then
asa#copy tftp flash
give the tftp server ip address
give the configuration file name (as exactly on the TFTP server)
reload
Apr 01, 2009 | Cisco ASA 5520 Firewall
Where can I contact whirlpool service center in Cebu City, Philippines
I'm in the laundry business in cebu. I have whirlpool washers and dryers. Call this person. His name is Cesar, 09198340747 or 0915-642-5766. Hope this helps.
Tom
Sep 25, 2008 | Washing Machines
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
