Question about Sony KDS-R60XBR1 60" Projection HDTV
Hdmi inputs used to work with my digital box and ps3... once i changed the bulb, the hdmi inputs stop working... what do i do
    Problem Solver:
  • 87 Answers
You might have a bad bulb. I have a question for you. I have a Haier plasma . Im trying to find a bulb for mine. here is mt email ianderson564@comcast.net.
Posted on Oct 17, 2010
My hdmi cord was is no longer able to be used and the regular cord from the ps3 wont work how do i get it to work
May be simple as changing your input on the TV. I know this is something usually over looked.
Jul 07, 2012 | Sony Playstation 3 (PS3) Console
I have lost all my HDMI inputs for my Hitachi L42X01AU, i had my PS3 hooked up and it worked but now when i hook it up none of the HDMI inputs work
try unplugged all units involved---HDMI does not like being hooked or unhooked with units powered and or on.
Wait a while and make the connections and then power set, box, whatever is inline back---the units will try to reboot and that may cure the issue- it is worth trying
Jun 17, 2012 | Hitachi Televison & Video
I have a 40" Apex LCD tv and for the past year
I dont know how to solve this but I have experienced the same thing. Two of my hdmi outputs dont work anymore.
Jan 08, 2011 | Apex Digital LD4088 LCD TV
PS3 hdmi only working on some displays
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
Issues Displaying picture from HDMI upconversion
I've posted this other places. Hope it helps.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
May 22, 2009 | Onkyo HT-S5100 Theater System
HDMI Input only reads Digital TV and not PS3 or AV Receiver
Well, I won't take the credit of others. Many people have the same problem as you do.
In the search box on the top of this page, put in " PS3 HDMI ". The one that has the 10 solutions so far has the best answers for you.
Good Luck
Feb 16, 2009 | Philips 52 In. LCD HDTV
Connection of PS3
You will have to connect it to the TV using the composite cable to change the settings. This is the cable with yellow red and white connectors. Connect it to one of the composite inputs on the TV. You should be able to leave to HDMI connected at the same time so that once you make the change, you can change to the HDMI input and see if it works.
Oct 26, 2008 | Televison & Video
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Lcd montior with tv box but no hdmi sound
in some cases certain manufacturers say in the instructions that when using s video with seperate audio, you cannot use the HDMI for the sound and sometimes visa versa, it's just the way the output is set up. Remove the other sound cable you are using for pc or tv and just use HDMI to confirm that the sound is re-enabled on the HDMI
Oct 02, 2007 | Sony Playstation 3 (PS3) Console
Sony KDS-R60XBR1 60" Projection HDTV Logo
97 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
