Question about Panasonic Viera TH-46PZ85U Plasma TV
We have a Panasonic TH-46PZ85U that we just replaced the power supply board in. In turned on immediately once placing it back on the wall and worked for hours. We turned off and came back hours later and would not turn on again. We went through the troubleshooting of removing the HDMI cord and pulling the power cord. We plugged the power back in and it worked but when we turned off and put the HDMI cord in it no longer worked. Would this by the Y-sustain board that was actually the problem?
  • 1 more comment
  • geofire2004 Oct 17, 2010
    We've already replaced the power supply board so it sounds like it's the y-sustain board then? We were told by Panasonic that the code (blinking lights) that it was the power supply board (98%) and possibly the y-sustain. Would there be any other reason for the weird failure?
    This morning I had the tv on and then plugged in the HDMI cable in the back and has been working fine. Is this maybe something where we have to turn the tv on before we turn on the cable (HDMI)?
    I'm guessing the y-sustain board is maybe a little more complex then swapping the power supply board? Either way, not looking forward to the 40 some screws that will have to be removed and then replaced. Ugh.
    Let me know what you think. I do not have an ohmeter...only a volt meter. Is this something I could get at a hardware store?
    I don't know if I've ever seen the standby mode.
    When it doesn't turn on it goes to the two blink pause sequence on the power light and doesn't turn on at all.
  • geofire2004 Oct 18, 2010
    If the tv is actually working then I'm hoping the power supply board isn't fried, yikes. Where would I get a service manual for this tv? I just have the one that came with the tv and it's definitely not a service manual.
  • Panasonic Master
  • 11,800 Answers
That code signals a failure in the high tension modules - since the power source was new then the only other board that uses those tensions - the Y-sus one - is defective. The good part is that now you know for sure what's the faulty board, the bad part now is that it might have fried even the new power board so before ordering new boards you should test them by measuring the voltages - the correct ones are on a sticker on the plasma panel.
Posted on Oct 18, 2010
  • 4,889 Answers
What happens when you try to turn it on(when it does not work)? Does it go into standby mode?
Posted on Oct 17, 2010
  • eagle338
    eagle338 Oct 18, 2010
    Yes it is the Sustain board also know as the energy retention board. The purpose of the board is to charge the capacitors on the board so as to ensure that there is enough voltage to light up the display. The sustain board as you have observerd is slightly harder to remove but I do not think there are 30 screws to remove. Your main challenge would be to remove the ribbon like cables and locks on either side. They have kind of latch like mechanism that will click into place. You should first rise up the the edge of the cable out of the slot and then rotate it in clockwise direction. For the lock it is anti-clock wise direction. The lock has to be removed to detach it from other boards in most panasonic plasmas I have seen. It might be a good idea to get a service manual to fix this one.
    Sai.
  • eagle338
    You can get it from here by registering(costs 5 bucks).
    http://www.free-service-manuals.com/Tele...
  • 11,896 Answers
The y board and the power board are the most common failures. You should really test them with an ohmmeter before replacing one or the other so you know for certain. Either the ysus board or power board is faulty.
  • Nate Stansfield
    Nate Stansfield Oct 17, 2010
    You could get an ohmmeter/voltmeter at the hardware store for an affordabe price. Shopping stores like walmart, kmart, target, ect have them as well.
    You can test power with a voltmeter from power supply/inverter to where it connects on the board. Then if you feel up to it but won't be necessary unless the inverter/supply puts out the correct voltage. Test the caps on the board to see if you get around 5 volts.
TV no longer powering up. Red power light blinks 10 times, stops, then repeats. Tried holding down the power button, turning off the tv for a while, plugging directly into wall instead of surge...
Bad or blown capacitors. Look on circuit board for domed, bulging or leaking capacitors. USE CAUTION!! high voltage capacitors can electrocute you. They should be properly discharged before working on circuit board
Jun 28, 2011 | Panasonic Viera TH-46PZ85U Plasma TV
Sometimes when we turn our TV on it comes on for about 15 to 20 seconds then turns off. The red light on the bottom of TV starts blinking then so we have to turn off the power strip and leave it off for...
Your power supply board is not yet dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com and Ebay.com to buy a whole refurbish power supply board for the replacement.
take care.
May 25, 2011 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic - TH-46PZ85U - Will not power up, either from the remote or from the TV on-off power button. With the TV plugged in, a light on the bottom left corner flashes 10 times, pauses and then the...
Could be a cooling fan failure, there are five fans across the back of this tv ( i think) if even 1 fails the power supply shuts down. If so fan needs replacing,
pete
Nov 11, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
I have a Panasonic TH-46PZ85U Plasma TV with a two blinking light code, no picture. How do I fix. I Have removed the back panel and looked for damaged caps but I do not see any.
hi; the blinking light code means that you have a fault in the power supply unit, unplug the tv from the power source, check all transistors you will find some of there shorted, just replace them; if you need a help about repairing i'll help you
Nov 06, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
My panasonic th-46pz85u has 2 blinking lights and wont turn on
The power supply board it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 21, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
The tv is not turning on all I get is a red blinking light next to the power switch
The power supply board is dead.That the board where the power a/c cord plug into it.Take the tv aparts,replaced the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 23, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic TH-46PZ85U when i turn on tv does not go on but red power light flashes. What can I do to fix this?
I unplugged the tv from the outlet, waited abut 20 seconds and plugged it back in. I was able to turn the tv back on. But, when I turn it off, and try to turn it back on with the remote, it doesn't always work.
Don't know if it's the power supply going?
May 12, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
I have a Th-46pz85u panasonic plasma tv that is blinking the power light 10 times. I was curious to see what the replacement part is to fix that problem. I have the Panasonic error codes and that error...
Yes,this codes is a 100% correct is ur power supply board.U searches all around the power supply board and it supporting boards for those leakages gases capacitors?These capacitors alway have bulges on it top or puff on it top.Replaced these bad capacitors,u will get ur power voltages stable and ur power supply board will work.Not,than one or more of ur power transformers have a shorted power pins legs.The power transformers,coil is dead.The transformer must be replaced.
May 03, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Power supply board is dead.Must change the power supply board to solved this.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 19, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
7 blinking Red Light. Power Supply problem??
Need replaced su.sd and sc board
Panasonic TXNSC1RKTUS SC BOARD BOARD, SCAN DRIVE ASSY
Panasonic TXNSU1RKTU SU BOARD BOARD, UPPER SCAN OUT ASSY
Panasonic TXNSD1RKTU SD BOARD BOARD, LOWER SCAN OUT ASSY
Dec 09, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic Viera TH-46PZ85U Plasma TV Logo
582 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
