Question about Canon PowerShot SD870 IS Digital Camera
How to remove and install a lcd screen on a Canon SD870 Powershot digital camera
  • keith29425 Oct 21, 2010
    Good photos and directions.
    It would be helpful to underline important verbs such as Carefully slide the data cable out of the connector in step 9 because it isn't obvious (until the step is finished) how the connector is attached. Also mention that the battery should be removed before beginning.
    Genius:
  • 1,035 Answers
Hi. Here's the link on how to remove and replace the LCD. Please click here.
Posted on Oct 17, 2010
I replaced the lcd screen. Now when the my camera is turned on i have a black screen with nothing on the lcd. Not even a menu display. I have pushed the lcd ribbon as suggested but no luck. Need advise....
The backlight is not turning on, it's the smaller of the two ribbon cables on the LCD assembly.
Make sure you have a backlight on your new LCD (not everybody sells it with the backlight!) or reuse your old backlight with the new LCD.
Check the backlight cable, is it ripped? Even slightly? If so, you need a new backlight.
Thomas Drayton
Owner Darntoothysam.com
Affordable Digital Camera Repair
Aug 03, 2011 | Canon PowerShot SD870 IS Digital Camera
Problem with flash on Canon Powershot SD870 Digital Elf
There is a problem with the flash or flash charge circuit. It will need to be repaired and may cost about $ 100 if not under warranty,
Apr 05, 2010 | Canon PowerShot SD870 IS Digital Camera
Grey pixel blob appears on lcd screen on my canon powershot sd870
I'm not sure but I have the same thing on mine and the warranty just ended.
Aug 18, 2009 | Canon PowerShot SD870 IS Digital Camera
Spot circle in screen
It’ a common problem on this model. The LCD screen is defective. Try to contact Canon for a free repair.
Aug 04, 2009 | Canon PowerShot SD870 IS Digital Camera
SD870 encountered water. Screen is now white. Does the screen need to be replaced or electronic components?
I know that when you take the ribbon cable off the LCD screen, and power the camera up, the screen is just white. It's probably that cable that came lose, or is not properly connecting. A good cleaning on the cable (behind the LCD screen) would fix it.
Jul 31, 2009 | Canon PowerShot SD870 IS Digital Camera
Gray pixels create couple of blobs
I had the same problem on my SD870. I sent it back to Canon and they replaced the LCD screen for free under warranty.
Jun 23, 2009 | Canon PowerShot SD870 IS Digital Camera
Blob of grey pixels overtaking the LCD screen on sd 870 canon
Canon will replace your LCD screen if under warranty. Same thing happened to mine. The blob got bigger and bigger.
Jun 14, 2009 | Canon PowerShot SD870 IS Digital Camera
White display screen
Sounds like the Backlight is working but the LCD is not. The first thing I would try is opening up the camera(if this is the sort of thing you are comfortable doing) and pulling out and then pushing in the LCD ribbon.
See this image for where the ribbon for the lcd connects (at least on a SD600).
http://3.bp.blogspot.com/_XmSxWfvnwsE/RlOsEjYjN5I/AAAAAAAAADs/0OuqTpB0GRc/s1600-h/plugin.jpg
Dissasembly guide for canon powershot (likely good for sd870 IS)
Mar 01, 2009 | Canon PowerShot SD870 IS Digital Camera
Line in the LCD screen
there is a very strong possibility that a part of the film circuit of the LCD was loose and somehow totally lost connection due to shaking and other forms of physical trauma.
here are some links you may find helpful:
http://cannonlcdrepair.blogspot.com/
Changing a Canon Powershot LCD
Hope this helps out
Nov 09, 2008 | Canon PowerShot SD870 IS Digital Camera
Canon PowerShot SD870 IS Digital Camera Logo
108 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
