Question about Zenith B25A02Z TV
Just got the Zenith model B25A02Z for my kids and went to plug in their Nintendo Wii to it. I can't find any RCA connectors on the TV. Can't seem to plug in anything except a cable wire. How can I get their game systems to work on the TV?
    President:
  • 2,992 Answers
On a TV that doesn't have any A/V inputs, you'll need an RF converter. This device takes the audio and video signals from a source such as your game, and makes a channel 3 or 4 signal that can be tuned in by the set. Converters are available in the TV accessories section of big-box retailers, at Radio Shack, and from many places online. They cost around $20.
Hooking up a converter is easy. You just plug in the A/V cables from the game, connect the output cable to the TV's antenna jack and plug in its power supply (it needs power). There's a connector on the converter to hook up your cable wire again since you have to disconnect it from the TV. It sounds like more trouble than it really is. Maybe 10 minutes.
Happy gaming, and thanks for using Fixya!
Posted on Oct 17, 2010
My Wii U wont work on my RCA TV!
U will need to get another av ..connecter...the color cords you said..there rca jacks..then it will work
Jul 29, 2014 | Nintendo Wii Video Game Consoles & Games
Tip
Reset your Wii Video Settings to the Default
One annoying thing about the Nintendo Wii is that there is no way to reset the video settings once you have changed them in the Nintendo Wii System Menu.
It will not detect which cables you are trying to use and just tries to use the last settings that you set it to.
So, if you have changed your Nintendo Wii from using the regular cables that came with the system to using component cables, then switch back to a TV using regular RCA cables (these are the yellow, red and white cables) then you need to reset the settings on your Nintendo Wii to the default video settings.
You can reset your Nintendo Wii video settings to use Composite (or RCA - Yellow, Red and White) cables by doing the following:
1. Make sure the Nintendo Wii is powered off and a red light is showing.
2. With the power off, unplug the video cables from the back of the Nintendo Wii, leave them plugged into your TV (these should be the RCA/Composite cables)
3. Press the Power button on the front of Nintendo Wii. Make sure the cables are still unplugged.
4. Keep the Nintendo Wii powered on and plug your cables back into it with it still running.
5. If all went well, the picture should appear normally now.
6. Once the picture has reappeared, you should go into the Nintendo Wii Menu (the Wii button in the bottom left hand corner) and change the display back to 480i to make the changes permanent.
I hope this tip helps!
on Apr 09, 2010 | Video Game Consoles & Games
We are trying to set up wii-through the dvr to play on Sharp LC-PD50U-unable to get it to work.
Connect the Wii directly to the TV either using the HDMI cable or the Hi def cable(5 RCA connectors) that come with the Wii. Then select the input number on the TV to get a picture .
Dec 25, 2012 | Sharp Aquos LC-PD50U 50 in. Plasma...
Connect a Wii to VCR
Hello
Take the Wii's audio/video cable and the power cord and hook them up in the back of the Wii.
Take the Wii's audio/video cable and plug it into the 'audio-in and video-in sockets on your VCR.Make sure you match the cable colors with the input colors.i.e white goes with white,yellow with yellow and red with red.
Take the RCA cable which looks like the picture below,
and plug one end of this audio/video cable into the 'audio out' and 'video out' ports on the VCR.Make sure the cable and ports colors match.
Now take the other end of the RCA cable and plug into the 'audio in' and 'video in' ports on your TV.Again make sure you match the color connections.
Hope it helps.
Ken
Jan 22, 2012 | Nintendo Wii Console
I accidentally set my wii to HDTV settings and I need to reset it back to normal tv but my screen is so messed up I cant see options or anything
May 01, 2011 | Nintendo Wii Console
I have a 1998 zenith color tv and i want to attach a wii. I plugged the video cords to the inputs and turned the wii on and the tv on to aux The wii does not display on the tv. Please...
Are you SURE that you have the wii plugged into the inputs of the tv - red to red, white to white and yellow to yellow? (You would be surprised how many people plug them into the output rca plugs.) Are you SURE that you have the correct aux selection - many tvs of that timeframe have two: a front and a rear. If your wii cable works on another tv (try it if you don't know), then my guess is that your tv is not working right. You could try using an rf converter to plug it into the rf connector (threaded) of the tv and run the tv on ch 3 or 4.
Nov 30, 2010 | Televison & Video
Friends Nintendo Wii went off - screen turned black after previously working ok. Took our Wii and plugged it into their tv and wiring. Our Wii now wont work. When Wii is turned on screen changes from no...
  1. This happens if the wires are hooked up wrong(Video and Audio reversed)
  2. The tv is on the wrong channel
  3. The tv signal settings have been changed
  4. The signal settings on the wii have been changed
First check that all wires and connectors on the wii and tv are properly and snugly connected
and check the tv channel.
Then check the settings in both.
Please rate this fixya solution
Feb 22, 2009 | Video Game Consoles & Games
Installation of wii
I had the same problem on a 32" rca crt. It worked fine, power was cut during electrical work and when it came back, "unusable signal." I went into the menu, then channel, then video input source. had to change it to the correct input "s-video in my case" Then it worked. GOOD LUCK!
Feb 14, 2009 | Nintendo Wii Console
Only DVD works
rca jacks may be goin out, one of our did that and i had them replaced for under 20 bucks, jason
Dec 13, 2007 | Zenith B25A02Z TV
Zenith B25A02Z TV Logo
114 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
