Question about Manfrotto Photography
Removing Tripod head from center post on Manfrotto Modo 785B
I've searched everywhere and I can't seem to find anyone who can explain how the tripod head on the mini Manfrotto (MODO) is removed from the center post. I've already ordered a replacement and am leaving on a trip in about 2 weeks, so I'm under a crunch!!! Please help!
Thank you
I have the national geographic branded version. Here is how you remove the head.
(1) remove the center post from the tripod
(2) lock the ball head with the trigger lock
(3) grasp the body of the ball head with one hand and the center column with the other.
(4) turn counter clockwise.
If you're intending to replace the ballhead, be warned that the thread is non-standard. I have a new "plug" with a standard 1/4" thread made for free by the machinist at my job. I don't know how you would go about adapting it without such a capability.
Posted on Feb 06, 2009
  • 22 Answers
Contact Bogen in the U.S.A, They are the exclusive importer of Manfrotto products, On some models, the center post and the head need to be replaced as a unit- check with Bogen.
Ed
Posted on Jun 13, 2008
Camera quick disconnect is missing
Posted on Jul 25, 2013
Video camera attaches backwards
Is the anti-rotaion pin in the way? It is the fixed pin that may not allow you to mount the camera correctly,if the camera does not have an anit-rotation hole. You can remove the pin and it should work fine.
May 13, 2014 | Manfrotto Modo 785B Tripod
Hi, I have just bought the 190CXPRO3 carbon fibre
Little confused here. Is the head the part you want to detach from an older set of legs? Do you want to remove center post from new legs or old legs. The base plate remains on the center post/ Aftre removing 3 set screws, and you want to remove the head from the baseplate and it will not turn, grap slip joint pliers or a pipe wrench, wrap the jaws with cloth ( to prevent marring of head or legs) and while holding head with wrench, have someone else turn legs
Apr 26, 2011 | Manfrotto (190XB,128RC) Tripod
How do I take my ball & head from the normal position to the center position inside the tripod legs? I want to use it for close up macro shots.
I was unable to find a picture of this tripod and head arrangement so on experience only I'll suggest how to do this. All of my Manfrotto tripods whether round tube or octagonal center post design work the same way. At the the bottom of the center post is a cap, it might be a rubber plug, twist lock type with a hook, or a rectangular stopper. Which ever this plug/cap can come out will a little effort. It's there to prevent the user from inadvertently pulling the center post out while extending to maximum height. You need to loosed the tension scree/lock off loose but not necessary to remove the screw. Then remove the center post by pulling it right out of the tripod housing. Now invert the post and reinstall it from the bottom side up, the tricky part is to realign the friction/tension lock and sometimes I use a pen/pencil to hold it over to the side while I insert the center post. once in place tighten the friction lock. The draw back I had at first was using the camera upside down. I've since solved that problem with a C type bracket. Hope this helps
Jan 03, 2011 | Manfrotto 3005D Tripod
I'm trying to attach a Canon EOS Rebel XS to a Manfrotto 190XPROB tripod, but the tripod socket on the camera is too small. How do I attach them?
You need a head. The tripod has a standardized screw for accepting a tripod head, which is a larger screw than for the tripod mount on the camera. There are a variety of heads available, ball heads, three-axis heads, geared heads, pan-and-tilt heads, and more.
Here's a page showing Manfrotto heads:
http://www.manfrotto.com/Jahia/site/manfrotto/cache/off/pid/1888?livid=80&idx=80
Aug 11, 2010 | Cameras
Broken leg clip on Manfrotto Modo 785B tripod the head is non-removable on this model and I don't want to have to replace whole tripod so is there somewhere I can buy a new leg clip or get it...
Yes you can. But I saw that your Manfrotto is possible to buy for 50 Euro.
Anyway the part you need is the full leg called CODE:
R785,203B
you can see the datasheet on the spare part site of Manfrotto:
http://www.manfrotto.com/webdav/site/manfrotto/shared/manfrotto_nord/pdf/7/785B_20070503.pdf
Regards
PDG
May 09, 2010 | Photography
My fluid video tripod head is stuck to the tripod. help! note: i have the manfrotto 503hdv head, and the legs are actually manfrotto 055CXPRO3 i have tried tightening the head controls. i have...
Make sure you are loosening the 3 grub screws under the tripod head to release it from the tripod center column. there are the 3 slotted screw heads under the grey part of the tripod head. Make sure you back them all the way out before you start to loosen the head.
Jan 28, 2010 | Manfrotto 503HDV Head and 351MVB2 Tripod...
Who do I contact to get repair of quick release's on 519 tripod
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen.
Jan 18, 2010 | Bogen Communication Bogen / Manfrotto 519...
Stolen Part on manfrotto 785B.
You can get the quick release replacement. You need the 785PL. Check this site for parts order.
http://www.tripodquickrelease.com/Bogen_Quick_Releases.htm
Hope this helps and get you back into action.
Andrew
Nov 01, 2009 | Bogen Communication Bogen / Manfrotto 785B...
Bogen Tripods, changing heads.
I searched around and all I can find is this: http://www.manfrotto.com/Jahia/site/manfrotto/pid/2477
Jul 02, 2007 | Bogen Communication Bogen - Manfrotto...
Photography Logo
3,751 people viewed this question
Top Manfrotto Photography Experts
JP Services
JP Services
Tom Chichester
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
