Question about Gateway FPD1530 15" Flat Panel LCD Monitor
What should my pixels be? - Gateway FPD1530 15" Flat Panel LCD Monitor
  • 11,361 Answers
Tip
Why the white or black spot on LCD Display
Dead and Stuck Pixels <br /> Pixel defects for an LCD monitor are defined as one of two types: dead or stuck. Technically, both types of pixel defects are stuck pixels but it really deals with the electrical currents and the state of each pixel or sub-pixel. <br /> A dead pixel is defined as a pixel or set of sub-pixels that has failed and is permanently in the off position. This condition means that the pixel will not let any light through. This can be observed as a dark or black spot on a brightly colored or white background. <br /> A stuck pixel is defined as a pixel or sub-pixel that has failed and is permanently in the on position. This can be either with a single or multiple sub-pixels for a given pixel and is best observed on a dark or black background. A white pixel means all three sub-pixels have failed while a green, red or blue pixel means one of the sub-pixels has failed. <br /> Hope this helps, if so do rate the Tip
on Jan 16, 2011 | Televison & Video
Is it true that when one pixel goes out, others are soon to follow?
No, that's not true at all. Each pixel is its only little device - one pixel does not effect another. The pixels work together to make a picture, but are all controlled separately. If your pixel is "stuck" and not dead, then you may be able to fix it! A stuck pixel is red, blue, green or white, while a dead pixel will show up as black. Sometimes a stuck pixel can be fixed by covering a pencil eraser with a cloth and pushing down on the pixel gently while the TV is on. So, in summary - no, one bad pixel doesn't mean any other pixels are bad. Hope that helps, Alex
Jun 01, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My brand new LG 37' Led/Lcd t.v. had four very light white spots that you can see in the background what causes this?
Hello
Hope this helps, if so do rate the solution
Jan 16, 2011 | LG 37LC7D 37 in. LCD HDTV
Pixel shader
A pixel shader computes color and other attributes of each pixel. Pixel shaders range from always outputting the same color, to applying a lighting value, to doing bump mapping, shadows, specular highlights, translucency and other phenomena. A pixel shader alone cannot produce very complex effects, because it operates only on a single pixel, without knowledge of a scene's geometry or of neighboring pixels. A pixel shader is a computation kernel function. Pixel shaders can alter the depth of the pixel (for Z-buffering), or output more than one color if multiple render targets are active
Feb 02, 2009 | ATI RADEON X1650 Graphic Card
What is pixel shader
Here is the answer right of Wikepedia.
A pixel shader computes color and other attributes of each pixel. Pixel shaders range from always outputting the same color, to applying a lighting value, to doing bump mapping, shadows, specular highlights, translucency and other phenomena. A pixel shader alone cannot produce very complex effects, because it operates only on a single pixel, without knowledge of a scene's geometry or of neighboring pixels. A pixel shader is a computation kernel function. Pixel shaders can alter the depth of the pixel (for Z-buffering), or output more than one color if multiple render targets are active.
Nov 30, 2008 | Computers & Internet
NEED TO CHANGE PHOTO RESOLUTION
■ Number of pixels
Select a higher number of pixels for clearer
pictures when printing.
Select a lower number of pixels [ ] (0.3M
EZ) to store more pictures. Fewer pixels also
means it is easier to send pictures by e-mail
or use them on a homepage.
■ When the aspect ratio setting is
[h]
DMC-LS75/DMC-LS70
(7M)
3072 × 2304 pixels
DMC-LS60 only
(6M)
2816 × 2112 pixels
DMC-LS75/DMC-LS70
(5M EZ)
2560 × 1920 pixels
(3M EZ) 2048 × 1536 pixels
(2M EZ) 1600 × 1200 pixels
(1M EZ) 1280 × 960 pixels
(0.3M EZ) 640 × 480 pixels
on the menu I believe the Panasonic calls it aspect ratio
Mar 06, 2008 | Panasonic Lumix DMC-LS75 Digital Camera
Gateway FPD1530 15" Flat Panel LCD Monitor Logo
21 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
