Question about Bazooka ELA300.1 Car Audio Amplifier
My Bazooka ELA300.1 amp was working great and it just randomly shut off. No lights are on at all. It just won't turn on. All the connections appear to be attached and all the fuses are intact. What do I do?
2 Suggested Answers
  • 631 Answers
SOURCE: No idea!!
Have you checked the on-board fuses on the amp?
Have you confirmed, with a multimeter, that you have B+ and remote voltage AND a good ground? If not, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Sep 29, 2008
How to i find out whats wrong with my bazooka tube i tried to hook it up to a car battery and car stereo out side but wont work ???
follow this steps and fix it. GOd bless you
  • Verify that the amplifier is turning on by looking to see that it is lit up.
  • 2
    Use a voltmeter to verify your power supply is a good 12 volts by touching the ground lead to you amplifier's ground screw and the positive one to the amplifier's constant power supply screw. Also verify that you have 12 volts coming from the remote lead wire which is usually a thin blue wire between the ground and constant 12 volt supply.
  • 3
    Look for the "thermal overload" light. It is usually a red LED on the side of the amp. If the amp feels really warm and this light is lit, the amp has probably overheated from being tuned wrong or turned up too loud and shut itself down to cool off.
  • 4
    Check the fuses on the amplifier. These can blow with extended use or during heavy bursts of use.
  • 5
    Make sure the "Gain" and other volume controls are turned up.
  • 6
    Confirm that the signal wire is still attached to the amplifier and has not come disconnected by vibrations in the car. Also check that the wires running out of the amp to the speakers are still attached to the amp.
Oct 27, 2013 | Car Audio & Video
Audiopipe amp 1000w on 2 8" double ended bazooka
You may be over driving the speakers or there may be an impedance mismatch between the amplifier and speakers, especially if they are connected in parallel
Nov 12, 2012 | Car Audio & Video
Csa300.1 bazooka 500 watts
sounds like you may have blown your sub...sheck the spyder inside of it and see if it is stiff..if the speaker doesnt seem too responsive when you press on it, its probably blown...
Aug 01, 2009 | Bazooka ELA300.1 Car Audio Amplifier
Bazooka BTA series self-amplified tube subwoofer wont' power on
the blue wire is called the remote wire will go to back of head unit also to a bule wire that will send 2 amps to turn on the speaker only when the head unite is on
Apr 18, 2009 | Infinity BASSLINK Car Subwoofer
Got the hot nd ground conted nd the aux cables from the raido conted nd the amp does not turn on
The amp needs a remote signal to turn on. This is provided by wire from the back of your head unit. Also look for a 'REM' or 'remote' connection on the amp (besides the 12v and ground connection).
Look at the wiring/setup diagram for your head unit to determine which wire/connection you should use for this.
If the head unit does not have a specific 'remote' wire, you can usually use the power antenna wire to provide a turn on signal to the amp instead.
Apr 13, 2009 | Bazooka EL1500 Car Audio Amplifier
No Power
It appears that there may be an open trace inside the amp. This assumes that the ground connection between the amplifier and the vehicle is intact.
Don't allow the RCAs to contact anything other than the RCA jacks of the amp. Some head units are easily damaged when the RCA shield contacts a power source.
The amplifier will need to be repaired. It's a simple repair and shouldn't be expensive.
Let me know if you have any other questions.
Aug 25, 2008 | Bazooka EL260 Car Audio Amplifier
Amp turns off after a couple minutes of playing
That's a new one on me.
The only electrical difference is the battery voltage on ACC is 12 volts. When you start the truck the alternator should put out about 13.7 volts. That would make me suspect a bad power supply in the amp or the output transistors, something in the amp is getting hot at the higher voltage and shutting it down
That would explain why you get two minutes ,and than when you turn the truck off the voltage drops back to 12 volts and the amp comes out of protect mode. Try a amp swap or if it's a self amplified tube, hook it up to a friends system.
Never hurts to put a voltmeter on the battery with the truck running, and off, to make sure the alternators voltage regulator
is not faulty and exceeding the rated voltage.
Good luck, let me know what happens, I'll ad it to the book.
Regards Paul
Jun 12, 2008 | Bazooka CSA150.1 Car Audio Amplifier
Stops working
THEY MIGHT BE DRAWING MORE CURRENT THEN UR ALTERNATOR CAN HANDLE.TRY CONNECTING A CAPACITOR FOR THE SUBS.
Feb 01, 2008 | Bazooka EL1204 Car Subwoofer
Bazooka ELA300.1 Car Audio Amplifier Logo
Top Bazooka Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Abubacar Alfredo
Abubacar Alfredo
Level 1 Expert
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
