Question about Video Game Consoles & Games
When turn on console. i have no red lights but it says please insert updating disc
    Novelist:
    Champion:
  • 210 Answers
The console did not fully install an update from a disc that was put in, the best way to resolve this is to clear the cache and put in the latest game you have.
Go to the Xbox Dashboard, select the System Blade, and select Memory.
Highlight the HD symbol and press Y.
Press X, X, Left Bumper, Right Bumper, X, X.
Note: Game saves, user profiles, demos, videos, music will not deleted during the process - But all game/console updates and error logs will be deleted.
After you have done this put the latest game in the console but DON'T close the tray instead just press the power button and let the console close the tray.
Now power on the console and click on the Game Disc and it should tell you that this game needs an update, just follow the directions.
Let me know how you get on.
Cheers
Posted on Jun 04, 2008
XBox Kinect says insufficient power I've tried unplugging and plugging into a single outlet but same problem. What can i try next?
Red light on the Kinect sensor Last Modified 16/05/2011
kinectred_300px.gif If the light on your Kinect sensor is red, the sensor might not be connected properly or your console software might need updating. You might also receive the following error:
The Kinect Sensor has insufficient power (C0051202)
Here's what to do to fix the problem:
update_error.jpg Solution 1: Update your console software
  1. Insert a Kinect game disc.
  2. Start the game from the Xbox Dashboard.
  3. If your console software needs updating, you will see the following message:
    Update Required: An update has been found, to apply this update you must restart your console.
  4. Select Yes, Restart to install the update.
If you still get the same error message, try the next solution.? ? ? Solution 2: Check the cables ? ?new360cableconnect.jpg
Xbox 360 S console
  1. Turn off the console.
  2. Unplug the sensor from the console, and then plug the sensor cable into the AUX port on the back of the console.
    Important Remove the power/USB adapter cable if your Kinect sensor came with one.
  3. Turn on the console.
Original Xbox 360 console
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
  4. The light located near the middle of the split cable should be green.
    No green light? Try plugging the cable into another outlet to make sure the cable is working properly. If you still do not see a green light, your cable needs to be replaced. Contact Xbox Support.
  5. Turn on the console.
If these solutions do not solve the problem, the sensor needs to be repaired. To start the online repair process, go to myservice.xbox.com.
Jul 04, 2011 | Video Game Consoles & Games
I try to turn on my playstation and it loads up fir a second and then cuts out, with a flashing red light on the console. If I press the red light it goes back to standby mode. How can turn my playstation...
If ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
still the same problem,don worry check out the following Repair Guide....
click here to download repair guide
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
I bought a new xbox with 250gb, when i turned it on it says please insert disc that came with device but it didn't come with a disc, I never heard of an xbox coming with a instalation disc, help PLEASE!
If you have a Kinect Sensor connected to the Xbox 360 S, turn off the console first and remove the Kinect Sensor. Then, restart the console and go through the initial set up. After the set up is complete, turn off the console and reconnect the Kinect Sensor. Restart the console and you will be prompted to insert the game disc that came with the device, which is Kinect Adventures. Insert the disc and it will update the console then go through the Kinect set up. Problem solved.
Nov 26, 2010 | Microsoft Xbox 360 Console
Wont turn on red light keeps flashing
PS3 won't turn on and keep red light flashing : You need to repair your console. Learn the step-by-step way to fix your PS3 components is best solution for you. I suggest a secret repair kit for you to fix the PS3 errors. This is an all-in-one style guide that help you to fix many cases of PS3 problems. The author is really kind and helpful to his customers. Learn the D.I.Y. way to fix PS3 issues can save you much money. You will receive much more than you spend on it. Because you can help your friends to fix their PS3 too! Please consider to buy it and share what you have learned !
PS3 Red Light and Yellow Light Fixing Guide : http://bit.ly/fixya-ps3
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
My 12th old ps3 has been faultless until 6/2/10 .It will not boot up at all .The start up red light turns to green as per normal then after 2 seconds it flashes red and goes back into stand-by mode Any...
That is the PS3 "Red light of death"
The articles below could help you fix them :)
<a href="http://ezinearticles.com/?Have-You-Got-Issues-With-the-PS3-Red-Flashing-Light?-Fix-This-Problem-Today&id=3629324">PS3 Red Flashing Light</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-Fix---Quick-Guide&id=3512073">PS3 Red Light Fix</a>
<a href="http://ezinearticles.com/?PS3-Blinking-Red-Light-Problem-Solved---If-You-Have-This-Problem,-You-Really-Need-to-Read-This&id=3512063">PS3 Blinking Red Light Problem</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-of-Death---How-to-Fix-it-Quickly-and-Easily&id=3512067">PS3 Red Light OF Death</a>
<a href="http://ezinearticles.com/?Thinking-About-Buying-a-PlayStation-3-Repair-Guide?-Then-You-Better-Read-This-Before-You-Do!&id=3676847">Playstation 3 Repair Guide</a>
Feb 07, 2010 | Sony Playstation 3 (PS3) Console
Inserted blue ray disc into cold ps3, now dead dead dead
Does it have a red light in front or nothing? If you don't have anything then your power supply has went out and you can pick one of those up for 40-50 dollars on eBay.
Thanks,
Ced
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
Unplayable disc and insert a game but it is
Did you get the disc or the console fixed. If it gives u the error saying please insert this disc ito an xbox 360 console, then blow on it and clean everything.
If its a dif error tell me. I no how to fix a couple red-ring problems.
Jun 17, 2008 | Microsoft Xbox 360 Console
I RENTED ASSASINS CREED...
insert the hard drive update disc...sheesh...kind of obvious! Don't have one? Buy one!
Mar 10, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
35 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
