Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
My bissell 2x will not sunction anymore. I have only used it~5 times and in the beginning I had to empty 2 in 1 often. What could be the the problem? Also I wipe the bottom often so it will not impede this very important process.
  • Bissell Master
  • 15,682 Answers
The issue is suction is being lost somewhere. The problem could be in the head where the suction is divided between the hose and the head. Check to see if the switch for that is working. You should be able to see a flapper close when it is on floor cleaning. You can also plug the hose by hand and see if this helps. Make sure that the filter on the tank is clean, IT is a little square plastic screen that pops out.
Posted on Oct 17, 2010
No liquid through accessory hose
Hello, this is Ava with Think Crucial.
There are a number of reasons why your unit doesn't spray water. It could be that the !) water tank is empty which you can fill heavy duty bladder with hot tap water. 2) If Formula tank is empty, you can fill it with Bissell 2x formula for cleaning. 3) If tank may not be seated properly, turn the power off, remove and reseat the tank. 4) If pump may have lost prime, try to turn off and then turn on the unit, wait for one minute and depress trigger. If still nothing happens, I suggest you contact Bissell 1-800-237-7691 for further assistance.
I would like to let you know that you can order replacement parts for your vacuum needs. Please visit our website http://www.thinkcrucial.com/search?type=product&q=bissell
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Nov 08, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2X pet will not spray water.
Bissell 2X machines all seem to do this after 4 or 5 uses. It's a bad solenoid. Most vac shops won't touch the 2X with a 10 foot pole. Get a Hoover 5914 and stay problem free.
Oct 18, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel pro2 carpet cleaner stopped sraying how to fix
Hey Diane! Sorry you're having difficulty with the spray on your ProHeat 2X. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Bissell 2X Proheat 9200 rug cleaner
How to put the bissell 9500-5 together the way the factory would do from the begining
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wwty
May 21, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Pro heat 2x the shampoo tank empties out
the o-ring is likely dislodged on the screw on cap
personally I would recommend just filling the soap container with water and a little bit of white vinegar instead of the detergent. You won't leave soap residue in your carpet that way.
Dec 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Anyone know why my Bissell Proheat 2X Turbo Model 9300's brushes won't turn anymore
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Nov 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat 2X Cleanshot won't turn on at all
heatman101
fgfg
May 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9200 Proheat 2x carpet cleaner
cleaner will not start
yes, I plugged it in!
Aug 07, 2008 | Bissell 9200 Upright Vacuum
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
23 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
