Question about Kenmore Elite HE4 Electric Dryer
Moved the dryer to a new home and the auto dry feature seems to leave the clothes damp compared to old location. Tried in all three settings.
  • Kenmore Master
  • 7,482 Answers
BE SURE TO UNPLUG YOU MACHINE FROM THE WALL BEFORE YOU START ANY WORK.
Your problem could be a Thermostats/Thermistors malfunction.
But this overheat condition also could be caused by a buildup of lint in the duct work, or a faulty blower motor/fan blade.
This will cause an overheat condition that you describe.
You will have to locate the air tube that is going to the dryer drum.
Same general area the heater is located is also where you will find most of the thermostats/Thermistors.
They normally are round/oval shaped and have two wires connected to them. Take off the wires and with an Ohm meter set to "continuity" check your thermostat/thermistor.
If you have continuity across the terminal it is not faulty.
Be sure to check all of the thermostats/Thermistors.
If this is not your problem then it will be the Control board if you have one on your machine.
Look for the fan blade to be in the air tube going to the dryer drum.
This is a FREE answer, Please Rate Me
Posted on Oct 17, 2010
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Wirlpool Estate Gas Dryer that does not dry
i think your temperature sensor is defective in the dryer section..
check it out
May 04, 2008 | Dryers
Problem drying clothes
This is the classic symptom of "poor air flow". Another symptom you didn't mention (but I bet is happening) is that the top of the dryer gets VERY hot. OK, don't move your dryer yet... get a flashlight and look behind there. See the flexible vent connecting the dryer to the wall? It must have SMOOTH, FLOWING turns. No crushing allowed. If it's crushed/pinched, you found the problem. It's "choking" off the air flow... not allowing the hot air to escape and containing all of it in the dryer cabinet. If this is the problem, pull the dryer away from the wall about 8" and make sure the vent isn't pinched off anymore. Leave your dryer this far out, it'll ensure that this doesn't happen again. If the flexible vent is OK, there is a blockage in your house's internal dryer duct work somewhere. Turn the dryer on and go outside to where the exhaust is. Check air flow. Check the exhaust vent for debris (I've seen birds build nests in the outside exhaust, incubates the eggs...but your clothes won't get dry!). If your dryer location and the exhaust location are quite a distance (20' or more) from each other, you should hire a professional to come out and thoroughly clean it out for you. In this case, you should have this done once a year as part of routine Home maintenance. To test and verify my solution to this, you can remove the dryer vent from the wall and cover the end of it with a pair of old pantie hose. Then run the dryer as usual (the pantie hose will act as a secondary lint trap). You'll see that the dryer will be happy again and the clothes will dry in no time at all.
Aug 21, 2007 | Whirlpool GGW9200L Gas Dryer
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Feb 19, 2009 | Samsung DV448AEE Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Frigidaire Dryer Auto Dry Cycle
You may not be giving the auto-dry feature enough run allowance. Set it for more dry and see how it works.
May 27, 2008 | Dryers
Dryer seems to work, but clothes end up damp?
Corwyn, looks like the problem you are having is not with the dryer. The vent line is probably clogged up, which caused the moisture to stay inside the dryer. To make sure this is a vent problem, you can disconnect the vent hose behind the dryer and run it for one load with it disconnected. If it runs fine, then the vent line needs cleaning. Usually it needs special equipment and is very hard to do yourself. It would cost you around $90 to get a professional out to do it for you. Gendos....post back.
Dec 19, 2006 | Whirlpool LER6636PW Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
