Question about JVC Televison & Video
I cannot turn the tv on manually. I have a 2 yr. old child who was playing with the Time Warner remote and did something. I tried to fix the problem using the remote. I somehow turned the tv off using the remote. I tried to turn it back on and it would not work using the remote or manually. when I called Time warner to help, they said it was not there problem, it was the tv. I don't understand when it was there remote that turned the tv off.
  • JVC Master
  • 17,130 Answers
To make sure that the set is receiving power to the main board of the set, you must see if there is any indication in the front panel.
If not the TV has a power problem that had occurred along with the switch off.It can be a coincidence that the set failed as you tried to set it right... can even be a fuse in the SMPS.
If so I request you to check for some tips to repair and check the SMPS unit. Try this link below:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
If however the power is present to the microprocessor check the crystal oscillators, soldering on the mP pins. Now you can also try to remove off the plug of the TV and the battery from the remote control for about 12 hours to make sure a full reset happens.
If the set still does not power on , you must cross check the remote for IR emission, the IR detection in set , the processor in main board to function accordingly..
The advice/tip given is with the belief that you are competent. You must attempt to do it yourself only if you are technically/logically able, especially when dealing with delicate devices, damaging while trying to open, Probing electrical/electronic circuits with high voltage or delicate components. Since the advice given by me is with the inputs provided and not based on a visual inspection, there can be further reviews required in some cases.
Posted on Oct 17, 2010
Time Warner codes for Mitsubishi tv
If Time Warner remote is universal, you probably can use its code search feature to find something that will control your Mitsubishi TV. Also, Time Warner might be able to tell you what code to use.
Jan 14, 2015 | TimeWarner Cable Time-warner cable...
Where is "set" button on the remote so I can set DVD code?
You need to be using the TV's remote, not the Time Warner remote.  You are reading the TV's manual to set it's remote, not the Time Warner remote.  If you want the Time Warner remote to operate the TV, you will need to find the instructions that the Time Warner box/receiver provides and enter the TV's code.
Mar 24, 2009 | Toshiba 36A50 36" TV
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
Battery good....remote light comes on....
Most Fan Remotes have to have the Battery compartment opened and the tiny rocker switches changed as well as the FAN receiver,could your child do that?.Try changing the Batteries.Good Luck.
Sep 11, 2009 | Universal Remote Control Hampton Bay...
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
Had a universal remote for my symphonic wf2703 tv my daughter tryed to change something with the remote now plays the dvd player ok turn it off all that comes up is a black screen with video on it the...
I had to clean the sensor area for the remote on the tv somehow got something on it. I wonder how, my little 4 yr old daughter had know idea how it got there lol.
Aug 01, 2008 | Televison & Video
Sony tv codes
Greetings...
What is the number for the TW remote you are using? 8400, U62R, 2000? Which TW cable service in NY... NYC, NY & NJ, Albany, etc...?
Ed
Dec 27, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Toshiba Child lock
You might want to try the same solution for the V-Chip (this might be the same thing as the child lock, it is worth a try) protection to see if this will help:
Changing V-Chip Settings for MV13L3, TV/VCR Combo 2001.
-Unplug your tv for 1 minute.
-Plug your tv in and turn it on.
-hold the volume down button on the tv at the same time you hold the "0" button down on the remote. This will bring up the "Set V-Chip" blue screen.
-Enter "0000" for the password and hit enter. Enter "0000" to confirm the password and hit enter.
-This will bring up the V-Chip set page. From this page you can: Turn Off the V-Chip, Change the Limits for viewing, etc.
-If you turn off the V-Chip setting, you will not have to deal with this problem again.
Dec 21, 2007 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
I feel like an idiot
I'm sorry to say that some TV's just plain don't work with a universal remote. If you have used all the codes that came with the remote, contact Time Warner support and tell them.
Unfortunatly the codes are not the TV's they are the Remotes, so unless Time Warner has a code that works or can walk you through the SCAN process successfully you might not be able to use it.
//D
Nov 25, 2007 | Philips PM435S Remote Control
Televison & Video Logo
43 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
