Question about Hayward Pool & Spa
Buying a pool heater. Which brand best reliability and service. Looking at Hayward H series cupro nickel 400 K Btu Nat Gas. Also considering Pentair MasterTemp CuproNickel 400 K. Will be heating an above ground 40 ft by 12 ft. In N Utah. Have 4 SunHeater panels 2'x20ft and solar bubble cover. Temp now 70 degrees after several sunny days. I cover pool at nite with some insulation panels [about100 sq feet] and pool cover and plastic tarps TNX
  • 990 Answers
Both of those heaters are fine I prefer the Pentair for it's smaller footprint and ease of installation as you can turn it for access to plumbing. The Hayward is tougher to turn the exchanger on and you only have right or left as options for the plumbing to come out. Sta-Rite is still my favorite for installation being easy to plumb, wire and run gas to. It's very easy to change from natural to LP also.
Most heaters today are the same in reliablity and that is mostly up to you to keep the chemicals correct. Being in the business I always look to ease of install and access for repair.
Posted on Oct 17, 2010
Testimonial: "Thanks for info from an expert. Think I will get a pentair as they are sold in UT. Wholesaler doesn't even carry Hayward. So Techs aren't used to. "
  • mr_markwilso Nov 12, 2010
    Our Pentair just quit on us. The combustion chamber pipes corroded in less than 2 years. Since the burn chamber is one self contained unit you can't replace a part of it and we had to buy a whole new heater.
  • deltameta2 Dec 08, 2010
    Sorry to hear that. Did you have chlorinator after the heater with a back check valve between? Did you run your chlorine at a low level like 1 PPM? I ended up with a Pentair and found tech customer service very good. Also I spent the extra for the cupro nickel metal tubes. Are you looking at buying over the internet? Thousands cheaper than dealers. Will Pentair give you a deal considering? There are several water chem issues beside Cl. Might be smart to bypass the heater when not used and somehow fill with fresh water [no CL] Sorry and good luck.
  • 640 Answers
Hayward makes a great above ground model. Sta-rite is also a great choice. Jandy and Pentair are user friendly and good quality pool heaters. If you stay with one of those four brands, you will be happy with your product.
Posted on Dec 07, 2010
Where is located pressure switch
inside front panel has 2 wires and a tube going to it
Apr 25, 2014 | Rheem M406A 399K BTU Cupro Nickel Pool or...
Hayward Heater H series 400 BTU will not start
This is a normal display when heater is being controlled by a remote thermostat. No service is required. If heater is not being controlled by remote thermostat, change setting by using the MODE key to put the heater into STANDBY. Press and hold the DOWN key and then press and hold the MODE key. HOLD down both keys for 3 seconds until the indication "bo" is removed from the display.
The key to this is DOWN first and then together with MODE, both for 3 seconds.
Make sure the display is not showing "BD".
Jul 06, 2017 | Hayward H Series Pool & Spa Heater 400k...
New Hayward Heater H series 400 BTU won`t light error IF
check gas pressure again meter could be too small if furnace goes on while heater is on it will run out of gas and turn off giving you that error
May 13, 2012 | Hayward H Series Pool & Spa Heater 400k...
Rheem M406A, HL2 fault
high limit bad check gas pressure over heated
Oct 16, 2011 | Rheem M406A 399K BTU Cupro Nickel Pool or...
Hayward pool heater c4205 has error message of LO
lo usually indicates insufficient water flow and/or pressure switch malfunction.make sure filter is clean and pressure is in normal range
Jun 20, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool & Spa Logo
324 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
