Question about SanDisk Sansa e250 MP3 Player
Sansa 240- gets power, but can't get to menu
My MP3 player turns on and initializes but will not go to any menu. Please advise how to resolve this, it has only been used about a dozen times for bike rides.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 11, 2008
My mp3 wont charge
This issue may be resolved by resetting it, try this.
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Jan 02, 2010 | SanDisk Sansa m240 MP3 Player
When I go to turn on my mp3 it takes a while then restarts itself over and over...it's happened before but resolved itself somehow?
Jan 02, 2010 | SanDisk Sansa e260 MP3 Player
Mp3 player is reading "No Files". I left my mp3 player connected to my PC and accidently turned off the PC, when I returned all of my files were removed. But when I try to download the old music it won't...
This is from Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
SOLUTION 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
SOLUTION 2 – If the problem was not resolved, download and Install the Sansa Firmware Updater.
SOLUTION 3 – If the problem was not resolved, format the device
WARNING: Formatting will DELETE all content in the player. Please backup all your data.
Please use Windows Explorer or Windows Media Player to format your device.
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 Menu won't show!!!! please help!!
STEP 1 – Reset the device
STEP 2 – Download and Install the Sansa Firmware Updater
I hope that helps. If not, please post a comment with an update to your problem.
Jan 01, 2009 | SanDisk Sansa e250 MP3 Player
My Sansa e200 mp3 player has frozen and i can't add anything.
First, try resetting the device as described in question 2
Dec 27, 2008 | SanDisk Sansa e200 MP3 Player
2GB SANSA Express
You may need to get either a memory stick to go in the available spot, or if you do not already have one and do not want to spend any money, get a paper clip and carefully stick it in the slot and it should come automatically.
Oct 28, 2008 | SanDisk Sansa MP3 Player
Software needed
Answer The power may be depleted fully or the Connect might be hung during boot. Charge the Connect for at least 20 minutes using the AC charger. If the Connect will not turn on after 20 minutes charging with the AC charger, you can then try using the Connect Recovery Tool.
The recovery tool will reformat and reload the latest firmware to the Connect. The tool and instructions are located here.
Note: Ensure the Connect is turned off by holding the power button 8-10 seconds before initiating the recovery sequence.
Answer ID: 450 Created: 05/14/2007 Updated: 11/08/2007
For Products: MP3 -> All Sansa Connect
Category(s): Audio Player
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Recovery tool
PDF on how to use recovery tool
Apr 01, 2008 | SanDisk Sansa e260 MP3 Player
Pb for my sandisk m230 mp3 player
Same thing happened to me... try this...
1) disconnect all cables
2) turn power on (hold menu button until screen lights up)
3) Press "menu"
4) scroll down to "settings"
5) scroll down to "USB"
6) select "MSC" (default is probably auto detect - which I think there's a conflict with)
7) turn power off (holding the menu button down)
8) connect USB to computer and hopefully start loading files
I bought 2 of the 512 models, one didn't work... so I took it back and had to buy a 2gig model... got home and it didn't work! I tried the above for the new one and at least the computer recognizes it! Everything seems to work fine...for now...
Dec 03, 2007 | SanDisk Sansa m230 MP3 Player
Not able to view files on my PC
I had the same problem, here is how i fixed it:
First, turn on Sandisk and go to settings , then scroll down to USB, and change the option selected, try both, see which one works,
Hope this works
Nov 26, 2007 | SanDisk Sansa m240 MP3 Player
My mp3 player doesn't work
My Mp3 dosn't work when i turn it on it says updating and when i put it on the charger it tells me instalzing i don't know what to do please help me.
Nov 27, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
27 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
