Question about Garmin StreetPilot C330 GPS Receiver
No power to garmin c330
I have charged my c330 for several hours on my computer and it shows charging. when i unplug and try to turn on it will not come on
  • foulis Jun 09, 2008
    The c330 battery went dead, I plugged into power outlet and system does not show that it is charging. Will not turn on when plugged in to charging sytem. I have checked that the power is working ok. This happened a couple of months back and after a couple of days I tried it and it tuned on?
  • Anonymous May 02, 2009
    I have the same problem with you, everytime i plugged the charger into the GPS it won't charge and it won't turn on either.
    What do u think cause this problem?
    So far, I haven't try to use the usb cable and connected from the computer.
  • 174 Answers
Does the unit turns on while pluged into the computer? If the answer is yes, then you will need to replace the battery. The battery is not taking a charge.
Posted on Jun 05, 2008
2 Suggested Answers
maklean
  • 1665 Answers
SOURCE: garmin c330 no power
Try changing battery and see again
Posted on Jun 03, 2008
StreetPilot C330 (010-00401-10) GPS Receiver: I just recently purchased a Garmin GPS system for ...
If there are no power points in your vehicle, you might have to purchase a battery-operated powerpack and plug the GPS into that via a USB/AC adapter.
May 18, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 no power
Jun 03, 2008 | Garmin StreetPilot C330 GPS Receiver
Shuts off, won't charge battery
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 26, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin won't turn on or charge.
Mar 23, 2009 | Garmin StreetPilot C330 GPS Receiver
I turned it on and it lit up and then completely died
Question: Why won't my StreetPilot c3xx power on?
Found on the Garmin web site --> Answer: If your StreetPilot does not power on, or if it turns on then turns off, you can troubleshoot the problem by resetting or charging the unit. The reset is a "soft" reset that you can perform in the car; it restores power to the unit, but it does not remove data.
To reset the unit:
  1. Place the unit in the cradle and roll it backwards slightly to lock it in place.
  2. With the key in the car ignition, turn on the unit or put it in accessory mode.
  3. On the face plate of the unit, put your thumb nail in the groove under the Garmin logo and gently pull off the face plate.
  4. With the face plate removed, press the reset button on the right side.
  5. Turn the unit back on. If the unit still doesn't power on, you may need to charge it.
To charge the unit:
  1. Using the provided USB cable, connect the device to the computer.
  2. Reset the unit (following instructions above).
  3. Keep the device connected to the computer and allow it to charge overnight (7-8 hours).
  4. After charging, unplug the unit and power it on.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 03/10/2008
Oct 05, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Street Pilot C330
Check the fuse at the tip of the power cord. Unscrew the round black plastic and this will release the fuse. Otherwise there could be a problem with the power cord. If the cord is defective, replace only a Garmin replacement.
Apr 06, 2008 | Garmin StreetPilot C330 GPS Receiver
How to charge garmin c330 gps from computer
The unit came with a USB cable. Plug this into the GPS (when it is turned off) and it will come on and the unit will charge while showing an image of the GPS connected to a computer tower.
Mar 19, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin wont stay on
How did you charge the unit? If you have not done so, try charging in on the computer for a few hours. Sometimes this can help.
Nov 24, 2007 | Garmin StreetPilot C330 GPS Receiver
Power On problem
Have you tried charging the unit on the computer? If not, charge it about 10 hours on the computer. This can sometimes help.
Oct 29, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
155 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
