Question about Garden
I have a ryobi hp472 and the battery will not recharge. Charger light never goes to green. Always stays red. WHat do I need to do. new battery or new charger?
  • 3 Answers
SOURCE: charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Posted on Jan 15, 2009
  • 636 Answers
SOURCE: ryobi 540A need manual runs slow/ chain too tight?
Loosen the bolts for the bar on the chain casing. Should be an adjustment screw either on the side of the chain casing or the inside front of the bar. Loosen screw and lift chain, chain drivers shouldn't lift past the bar grove .
Hope this helps you out.
Posted on Aug 14, 2009
Testimonial: "I will try tommorrow. Thanks so much"
  • 13 Answers
SOURCE: The Yellow and Green light both come on and stay
http://oneworld1.inetu.net/manuals/ryobi/hp1442m_1802m_874_eng.pdf
It sounds like your battery is bad. If yellow and green are on for more than 15 minutes it probably a defective battery pack. See page 8 in the manual.
Posted on Nov 24, 2009
  • 13 Answers
SOURCE: Green & Yellow light on 14.4V charger
If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
SOURCE: Ryobi p111 charger -- light stays red
My charger do the same thing. I talked with the service people at Ryobi who said that the red led never goes out no matter how long you charge it. They suggested just charge it for 12 hours and then disconnect. Pretty dumb system, but that's apparently the way it is.
Posted on Nov 30, 2009
I have a brand new Ryobi kit put battery in the charger the red light goes on and the green light flashers on and off is this charging or should the green light go off until battery is charged.
When the battery is charged the green will be steady on and the red will go off. Flashing green is an indication that it is charging.
hope this helps?
Jan 19, 2016 | Ryobi 18v Combo Kit P845 4-tools/...
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
Nov 26, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
I have a new Ryobi 18V Drill which came in a package from Screfix with two batteries. I charged one of the batteries to start with and when the green light came on I used it and immediately charged the...
Take it back to the store and tell them it is no good, and get a new pair of batteries, take the charger too. I had the same thing, brand new batteries, gone in weeks, they replaced them, no problem.
Feb 21, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
replaced.
Nov 24, 2009 | Ryobi Multi-Volt Battery Charger
Green and yellow lights both stay on and it never
see if your charger is under warranty and have it replaced..yours is bad..
Nov 13, 2009 | Ryobi Multi-Volt Battery Charger
Both green and yellow light stay on and batteries will not charge 18v
replaced.
Oct 19, 2009 | Ryobi Multi-Volt Battery Charger
Both green and yellow lights come on and stay on.
replaced.
Jul 12, 2009 | Ryobi Multi-Volt Battery Charger
Charger not charging
Jan 07, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Ryobi battery charger
Either the battery is hot from use or has been in the sun, let it cool down, then try again.
Nov 16, 2008 | Ryobi Multi-Volt Battery Charger
Garden Logo
310 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
