posted by tman10 on Jun 03, 2008
I have a JVC KD-LH910 and it doesn't have an auxiliary input in either the front or the back. I don't have the money for a new stereo and I don't want to use an FM transmitter of any sort. So I would really appreciate it if you helped me with my problem. Thanks
Solution #1
posted on Jun 03, 2008
The best solution if you are using the speaker outputs to power your system, though you specifically opposed it, is an FM modulator. If you are running any external amplifiers and only 1 set of RCA preamp outputs you could add a "switch" to the preamp input of your amp(s) to select between the headunit and an auxilliary source. I do not, however reccomend this as you may clip the preamp circuits and damage the amps. FM modulators actually do a good job of reproducing the frequency range and, if installed correctly, will not add a great deal of "noise" to the system.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Jensen CD-2010X CD Player
Jensen CM715K CD / Cassette Player
Jensen CD-615X CD Player
Kenwood KDC-MP528 CD Player
Kenwood eXcelon KDC-X879 CD Player
Kenwood 50W x 4 Apple iPod -Ready MOSFET CD Deck with Detachable Faceplate
Kenwood Sirius KDC-MP522 CD Player
Can you Help with these In Dash Receivers problems?
Repair Service
Find In Dash Receiver Repairman Near You:
