Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Does the poulan p2500 have a clutch - Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
    President:
  • Poulan Master
  • 1,545 Answers
It appears from the parts diagram that this model has no clutch.
http://www.ereplacementparts.com/poulan-p2500-gas-trimmer-parts-c-16962_17820_17826.html
Posted on Oct 17, 2010
Poulan P2500 weedeater want start
change over the fuel lines on the carby
Mar 24, 2016 | Poulan P2500 17" Gas Trimmer
Poulan p2500 carb adjustment
Carb not set correctly. Screw down idle an fast run screws an then reset. Sometimes fuel gets clogged an needs adjusting
Jul 04, 2014 | Poulan 25cc 2-Cycle Gas Powered String...
Need a free instruction manual e mailed to me for a poulan p 1500 16 inch 25cc gas powered weed trimmer
Sorry, but we are not set up to personal e-mail out... but here is the link you have requested. The page should show four choices for download by year of manufacture - click accordingly. If the selection does not show and the search parameters are blank, simply type P2500 into the "Type your search query (i.e. product name)" box and you will get the same results.
Hope this helps!
Jul 29, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
Need manual e mailed to me
Hello, hope this is a duplicate post. Here is the link you have requested. The page should show four choices for download by year of manufacture - click accordingly. If the selection does not show and the search parameters are blank, simply type P2500 into the "Type your search query (i.e. product name)" box and you will get the same results.
http://www.poulan.com/node7925.aspx
Hope this helps!
Need diagram of poulan grass trimmer te450 cxl
Hello, The link you requested is the top of the two, the second is the user manual. Hope this helps.
Jun 13, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
I read among your "unsolved problems" the same one I have. I have a Poulan 331 string trimmer, and the pull rope is broken. I have it disassembled down to the drum assembly, but I can't get that off to...
In the center of the drum (where the drive cable goes) is a torx screw. Usually it is a size T15 or T20. You will need a way to lock down the cylinder. If you don't have a cylinder lock, remove the spark plug, lower the piston down, fill the chamber with a long piece of clean rope or tubing (leave some sticking out), then raise the piston to lock the cylinder. The screw in the drum turns counter-clockwise to remove. After you get the drum off, then you will need to remove the clutch. It also turns counter-clockwise to remove. Use large slip-joint pliers on the clutch. DO NOT REMOVE THE OUTER PART OR SPRINGS FROM THE CLUTCH. They are very tricky to get back on. With the clutch removed, the rest should be relatively easy.
Aug 23, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
No Owner's Manual Came with My P2500, 17" Gas String Trimmer
Hello, It would appear that manuals were not included in this model :) Here is the link you have requested. The page should show four choices for download by year of manufacture - click accordingly. If the selection does not show and the search parameters are blank, simply type P2500 into the "Type your search query (i.e. product name)" box and you will get the same results.
Hope this helps!
Jul 30, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
I need to get a perpair manual for this type weed eater
Hello, Here is the link you have requested. The page should show four choices for download by year of manufacture - click accordingly. If the selection does not show and the search parameters are blank, simply type P2500 into the "Type your search query (i.e. product name)" box and you will get the same results. Beside that there is an "Illustrated Parts Lists (IPL)" choice, this will assist in your repairs.
Hope this helps!
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Replace starter cord assemble
the clutch is screwed on. you will need a small punch and hammer to loosen it to get the clutch off.
Sep 30, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
89 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
