Question about Sony VAIO PCG-K35 Notebook
Unlocking computer When I turn on my computer, the screen reads, "Locking your computer..." and none of the keys work. How do I get out of this?
  • lorrie74080 Apr 18, 2009
    my computer and windows are locked and I dont remember my password. how can I fix this
  • 458 Answers
Reset the CMOS battery on the Motherboard..
Posted on Jun 03, 2008
Why doesn't key fob lock/unlock doors?
Door Locking / Unlocking Problem - Kia Forum
www.kia-forums.com/kia.../68734-door-locking-unlocking-problem.ht...
May 9, 2011 - 10 posts - ‎4 authors Door Locking / Unlocking Intermittent Problem With Remote Keyfob ... being opendoesn't seem to prevent the car from locking, just the doors ... Power door lock issue
May 4, 2015
KIA Sorento 2013 car doors won't unlock while car is ...
Jan 20, 2013
Problem with key fob and unlocking the doors
Feb 16, 2011
Remote locking fob not working
Nov 13, 2010
More results from www.kia-forums.com
Nov 24, 2015 | 2013 Kia Soul
Toyota corolla drivers door not locking/ unlocking with key
Check the connector inside the door, whether is broken or not
Mar 09, 2014 | 1997 Toyota Corolla
2006 Jeep Grand Cherokee started, ran for a couple seconds then died now wont turn over. I've read that its an immobilizer issue, ave tried a couple of the "reset" procedures posted online....
But did you try howling at the moon with an aluminum-foil cone on your head and turning around 3 times? ;)
It sounds to me like it is time to have your computer systems scanned for fault codes. Most of the immobilizer system "fixes" posted online are temporary at best. (like the 10 minute time-out thing. That only works for certain types of failures when the system does not recognize your key on the first try. Even then, it doesn't fix anything, it only delays the inevitable for a while).
This could be something as simple as a shorted battery cell causing the computers to do crazy things, all the way to a failed control module or bad ignition switch. The only way to find out for sure is to ask the computer system that controls it.
Jul 09, 2011 | 1999 Jeep Grand Cherokee
My key won't turn in the ignition.
first try using the key both ways to see if one side is worn out. then , if that does not work try putting some dry graphite in the lock cyl and wiggling the key. you can also try tappin on the lock cyl with a hammer while working the key to see if you can rattle loose seized tumblers. if none of this works you can get a hold of your local chrysler dealer, and they cn cut you a new key by code NOT BY COPYING YOUR OLD WORN OUT KEY using your vehicle vin number. if none of these work you will need to get the lock cyl drilled out (best done by a proffessional) hope this helps
Dec 19, 2009 | 2001 Jeep Grand Cherokee
Central Locking to Ford Focus LX 2001
Hi, sounds like a lose rod inside the door,you need to remove the door panel to check it,....
Aug 28, 2008 | 2001 Ford Focus
Programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Jul 12, 2008 | 2003 Mazda Mazda6
Keyless entry remote
Try this, it works on several 2002 models:
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Jun 20, 2008 | 2002 Mazda Protege
Sony VAIO PCG-K35 Notebook Logo
46 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
