Question about Mitsubishi SL4SU ColorView Multimedia Projector
I have a Mitsubishi sl4su projector that I use for a tv but don't have a remote I got an s video cable to hook it up to my cable box but can not change the volume and don't know what to do any ideas?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
S video doesn't carry sound so you will have to use phono plugs too
Posted on Dec 08, 2012
5 Suggested Answers
Marrie
  • 563 Answers
SOURCE: MITSUBISHI HC 100 PROJECTOR
Hi there
First try to bypass the box and put signal directly into the Projector from the source - i.e. DVD Player
If the signal still doesn't pick up , try using a different cable.
If the problem is solved , then your Converter Box is faulty.
If the problem still occurs then you might have a faulty Mainboard - as all the inputs on this Projector is situated directly on the Mainboard.
Hope this will help you !
Posted on Mar 27, 2008
SOURCE: Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Posted on Mar 23, 2009
  • 4 Answers
SOURCE: My SL4SU projector will not
ok make sure its nt to close or far away and the focus ring should be in the midle to find out how to get a good focus hook up a laptop and search google for projector focus chart and use that and blam should be focused
Posted on Sep 21, 2011
SOURCE: When trying to watch a film off the computer through the projector the colour red comes out green on the projector.
go to image in the menu on projected and check rgb should be off
Posted on Nov 21, 2011
Zoom focus
It has a magnify feature on the remote I think. You can reset the machine by holding down power computer and video buttons for a long time.
Aug 23, 2013 | Mitsubishi SL4SU ColorView Multimedia...
How to reset the bulb life to 0 on a sl4su it
hi,
Do the following for reset the lamp hour to zero.
Reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for 5 seconds.
OK
Sep 21, 2011 | Mitsubishi SL4SU ColorView Multimedia...
No image is projected.
go through the sources, Computer,Video,Svideo
Feb 20, 2011 | Mitsubishi SL4SU ColorView Multimedia...
HOW DO I CHECK LAMP LIFE FOR MITSUBISHI SL4SU PROJECTOR
If you go into the menu of the projector.
Find the lamp status or info command.
It will tell you the current information.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
How do you hook up cable tv to my epson powerlite 830p lcd video projector
To hook up cable tv, you will need to have the cable running into a vcr 1st, then run either your s-video cable or audio video cables into the projector. Press the Source Search button on the remote control or the projector repeatedly until you see the image you want to project on the screen. The projector has two Source buttons.
Use the Computer/Component button to switch between equipment
connected to the Computer/Component ports.
Use the Video/S-Video button to switch between equipment
connected to the Video and S-Video ports.
? The remote control has four Source buttons. Use them to switch
between devices connected to the ports identified on each button.
(The PowerLite 830p does not support EasyMP.TM)
You can preview all sources on one screen to help you select the
desired source. (Allow a few seconds for the projector to sync up
after pressing the button.)
Feb 01, 2011 | Epson PowerLite 830p Multimedia Projector
My SL4SU projector will not focus all the way
Oct 25, 2010 | Mitsubishi SL4SU ColorView Multimedia...
check your cable and use a different laptop or desktop to eliminate the projector. always do a factory reset.
Sep 08, 2008 | Mitsubishi SL4SU ColorView Multimedia...
CONNECT CABLE TO MY PROJECTOR
Depending on the specific model of your Mitsubishi DLP, you can have either S video, RCA, VGA or a few other choices of INput connection.
Depending on your cable provider and hookup, you can either have a plain cable with F connector or a cable box normally with RCA connectors and a remote control.
If you have a simple cable connection that attaches direct to a TV (no remote, no box), you would need a TV Tuner to be able to receive the different channels whose output would be a composite video signal into the yellow RCA jack. You would need an RCA to RCA cable to in turn connect it to your Yellow RCA Video INput of the projector. In the absence of a tuner, an old VCR with such a feature would also serve the purpose. In some instances either units may also have an S video connection.
If you have a cable box with with remote, then there is no need for a tuner or VCR since its output would already match the projector's input.
Either way you would need a separate audio amplifier/speaker  for the sound.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Oct 23, 2007 | Office Equipment & Supplies
Mitsubishi SL4SU
what is the status and power doing because there is no information here
Oct 09, 2007 | Mitsubishi SL4SU ColorView Multimedia...
Mitsubishi SL4SU ColorView Multimedia Projector Logo
108 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
