Question about KitchenAid Kitchen Ranges
I have a kitchenaid pro line dual fuel range Model KDRP467KSS0 with consistent problems with the oven. Now the oven won't come on at all. Have t"tricked" into restarting before by cutting power and letting it 'rest" for a few minutes then restored all power and it started to work. Today, it did not work. solutions? Even the repair people from Kitchen Aid do not know how to work on this oven.
the dr
  • 447 Answers
SOURCE: Kitchen Aid Oven and Carbon Monoxide Leak
If you have Propane than any range will have to be properly converted to propane they are made for natural gas. Other than that gas ovens do emit quite a large amount of CO and new homes are built very air tight and any good CO detector may sense this. If you have a vent hood or hood/mwave combo and its vent is actually ran to the exterior it should aid in venting that CO. This is why the new dual fuel (gas cooktop, elec oven) are so popular. Hope this helps...
Posted on Jan 12, 2008
  • 2651 Answers
SOURCE: kitchen aid superba electric convection range
ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
Posted on Apr 03, 2008
Cyril J
  • 45 Answers
SOURCE: Kitchenaid Selectra Range Fuse location?
unit does not have fuses , if the top works ok then you are getting 220 volts , you probly have a bad control
Posted on May 16, 2008
  • 1922 Answers
SOURCE: blown fuse inmy kitchen aid range
if you havnt lost your main input 120/240 voltage then check around the control panel,you'll probably find a special control fuse in this area
Posted on Jul 28, 2009
  • 310 Answers
SOURCE: Kitchen Aid KESC307 Electric Range oven shuts down unexpectedly
We've seen similar problems due to an intermittent failure in the control board. If you can have it removed we can likely repair it for you.
Best Regards,
Posted on Oct 13, 2009
Testimonial: "Prompt response and likely the solution although I have not experienced the problem again. "
How do I unlock the oven door on kitchenaid classical commercial style dual fuel convection range?
disconnect the range form the power source, you should hear a pomp and the door should open
Sep 02, 2014 | KitchenAid Kitchen Ranges
Oven temperature is off by 25 degrees
Unplug the power and wait 15 minutes. Plug it in and retest to see if temp comes back to normal. + or - 5 degrees is normal. If still same problem than you will need to re[lace the controller board.
Dec 22, 2013 | Electrolux Icon E30df74gps 30" Pro-style...
Gas oven does not start
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Aug 16, 2011 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Oven flame on right hand oven doesent increase when dials turned up
The OVEN flame size is consistently one size.
The thermostat simply stays closed longer when asking for higher temperature in the oven.
Sep 22, 2010 | Rangemaster Classic 110 (Dual Fuel) Dual...
I was using the self cleaning function on my kitchenaid dual fuel range when about half way through the cycle the digital display went blank (i.e. no lights were on at all) and now 2 hours after the cycle...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 19, 2010 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Kitchenaid gas over will not come up to
To answer your question, in a word...Yes.
Quite often when the ignitor is faulty or on it`s way out, it manifest in not igniting the burner consistently, or at all.
If you`re still not sure though, If you could provide a model number and I`ll try to assist you further. The post is labeled as a ``dual fuel range`` which would lead one to believe the range has gas surface burners, combined with an electric oven. That is typically the industry meaning of a dual fuel range.
Hope that help`s and if so please take a second to rate this solution provided for you here at fixya.
Thank you and good luck.
macmarkus :)
Dec 06, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
I'm looking at a KitchenAide KDDT207B duel-fuel used stove to purchase used from a private party I don't know. Are there reliability concerns?
I have this same oven. It began to intermittently fail when using the oven. The error code suggested it was a problem with the keypad. I suspected it was because the electronics was overheating. The electronics for this model is approximately underneath the right front gas top range. What I found was that the failure occured when both the oven and the right front gas range were being used simultaneously. This caused overheating since the electronics has not fan in this model and the heat radiating down from the pan above the gas range is added to the heat coming from the oven below. The electronics is sandwiched between these two heat sources.
Nov 16, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Nov 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Kitchen Ranges Logo
81 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
