Question about Akai PT4298HD Rear Projection Television
Convergence problem: Green won't adjust
I have the Akai PT4298HD, recently the green convergence won't adjust. So what part should be replaced? And where can it be purchased? Thanks.
  • Akai Master
  • 8,617 Answers
You will need to replace both STK392-040 ICs you can get replacements at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Posted on Jun 04, 2008
My akai pt4298hd is out of zoom and
akai is a samsung tv. you have a defective convergence board. suggest local service center. sorry
Nov 14, 2009 | Akai PT4298HD Rear Projection Television
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Akai PT4298HD green convergence problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Akai PT4298HD Rear Projection Television
Convergance problem red, and green won't adjust
this is a common problem for all projection TVs the convergence ICs need to be replaced. Its an easy fix if you can solder. Let me know if you need further information or a link to where you can order replacements.
Nov 10, 2007 | Akai PT4298HD Rear Projection Television
Seeing red and green colors on screen
your tv is having convergence problems if you can't adjust it out with the customer controls you  probably will have to have the convergence circuit repaired witch should cost about $300
Oct 16, 2007 | Akai PT4298HD Rear Projection Television
Green Shadowing Around Images On Akai PT4398HD
your convergence amp's are defective this can usually be repaired for a few bills. easy fix for a qualified repair person...john
Aug 31, 2007 | Akai PT4298HD Rear Projection Television
Convergence
Seems like you need to replace its convergence amplifier ICs (2 pcs). The convergence amplifiers are attached vertically to two heatsinks. When replacing these, remember to reapply thermal paste (white paste for better heat transfer from IC to heatsink). If you don't replace these, over time other components will be affected.
Aug 26, 2007 | Akai PT4298HD Rear Projection Television
Akai
yep you need convergence amp replacment for your set..very common prob call experienced repair person for this job use original replacements....john
Jul 31, 2007 | Akai PT4298HD Rear Projection Television
My Picture is in Red and Green??
This is a convergence problem. From your menu, go to Menu, Function, Convergence and then use you remote to try to adjust your colors. If you can not get them to line up this is a problem with the convergence board. The convergence amps (STK392-040 x 2)are internally shorted. These can be replaced or the whole convergence board can be replaced. It's cheaper to replace the amps, but more convienent to replace the board (especially for the less electronically inclined!! :) Hope this help you out....
Aug 22, 2006 | Akai PT4298HD Rear Projection Television
Green projector alignment
convergence IC'c have three amps inside them. The green is fixed but still has convergence correction . Each IC uses the extra channel for the green. So if you are not a tech ask the repair person how much it will cost to replace both IC's. Remeber a TV set is not a place for an experimenter or a handi person, unless you want to get seriously killed!! Good Luck
Aug 07, 2006 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
67 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
