Question about D-Link DI 514 Wireless Router (DI-514)
I have a 524 wireless router and need a replacment power supply
    President:
  • 2,992 Answers
If the router has the voltage and current specs listed, there's no reason you can't simply get a regulated wall-wart from Radio Shack if they have one with those ratings (or the same voltage and higher current). They have several models with interchangeable tips, so you'll probably find one that fits. If you're handy with a soldering iron, you can always tack a pigtail onto the board with a different connector if you can't find a mate for the current one. I've never done this on a D-Link, but both techniques have worked on Linksys and Netgear routers. Just be careful of polarity. Sometimes the label doesn't show it, although tip-positive is most common. You can check with an ohmmeter to determine which connection is ground.
Good luck, 73, and thanks for using Fixya! (I'm KA3O, BTW, and now my cover's blown.)
Posted on Oct 17, 2010
Testimonial: "Thank you, I suspected it was a regulated supply, but not sure. Don"
Hello, when I enter http://192.168.0.1/ all I get as an answer is "Busy". What can I do to reinstal my D-link DI-524?
there should be some tiny hole near the power supply jack. try to press it with something suitable to reset the router then try again accessing through web browser using the address (192....)
Sep 18, 2011 | D-Link AirPlus DI-524 Wireless Router
The router was working fine, now its not. No lights on and it does not seem to be powering up
seems pretty straight forward. Its either the router that is dead or the power supply. Use the substitution method to isolate which one. You may have been hit by a power surge. routers are pretty sensitive to power hits.
Jan 14, 2011 | D-Link AirPlus DI-524 Wireless Router
When Di 524 is switched on all lights except Status and WLAN lights up. Router does not respond.
The wireless Router has not booted up properly. Please Power off and Power on ONCE again.
Oct 22, 2010 | D-Link AirPlus DI-524 Wireless Router
The STATUS led on my D-Link DI 524 wireless router
reset you router on factory set and then you can see the satus of lights.
Apr 04, 2010 | D-Link DI 514 Wireless Router (DI-514)
My DI-524 router flashing power light and flashing 4 light
try doing a factory reset on the router - you will need to know all the settings in the router as these will be needed to be re-entered button or hole on the back labelled reset , hold the button - or using a untwisted paperclip in the hole - for 10secs The router will now be reset
Mar 07, 2010 | D-Link AirPlus DI-524 Wireless Router
I have the d-link 524 that i use to connect my xp laptop via wireless connection and my vista desktop through a hard connection. What I found is that my wireless connection continually goes down and will...
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 13, 2009 | D-Link AirPlus DI-524 Wireless Router
Does DI-524 spport WAP
It looks like the 524 will support WPA-PSK.
Try this:
http://support.dlink.com/faq/view.asp?prod_id=1506&question=DI-524
If your 524 doesn't look like this you amy need to update the firmware.
Good Luck
May 06, 2009 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
D1-524 without power
this unit use an adapter rated at DC 5V 2.0A
the connector is the issue as long as it matches the above specs and the connector will fit.
take the dc adapter to any radio shack and have it tested.
Jan 26, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link DI 514 Wireless Router (DI-514) Logo
85 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
