Question about Polk Audio PSW10 Subwoofer
My polk audio powered subwoofer psw10 version has a blown fuse and everytime i put a 2A 250V fuse in it. it blows as soon as i plug it in can you help me figure out what is wrong
5 Suggested Answers
  • 3 Answers
SOURCE: AR1 Subwoofer Keeps Blowing the 5 Amp Fuse
I had the exac same issue. It started out with buzzing sound, but then quickly evolved into blowing the main 250V 5 Amp fuses immediately. I sent mine to ABTechservices.com and they found some blown resistors and leaking capacitors. I'm waiting to get it back (shipping to me now), but supposedly they have replaced and tested and all is working well. I'll let you know how it turns out.
The price they charged me, including return shipping was $187.50
Posted on Nov 11, 2008
lynchms
  • 93 Answers
SOURCE: best hook- up Polk psw10 sub woofer to yamaha rx-v663 receiver
You will not need to y connect your subwoofer, if you have only one RCA sub out on your receiver the other end of the RCA connector cable goes into the left input on most powered subs, there is no loss of signal, the option exist as some receiver do sport a double RCA sub out.
Posted on Feb 12, 2009
SOURCE: Polk Audio PSW10 not working
I just read this same problemin a psw10. It was recomended to remove back panel and there should be a fuse behind there. Check it out.
Posted on Feb 13, 2009
SOURCE: subwoofer eating fuses.
Check the circiut board for any blown capacitors. Sometimes it's that simple as replacing a capacitor. But then again, what is causing the capacitor to blow??/ Hope this helps.
Posted on Aug 01, 2010
Hi I have a Polk PSW10 it keeps blowing fuse as soon as I plug it in after replacing fuse
Fuses blow when there's an overload. The most common cause is a shorted semi-conductor in either the power supply or the main amp stage.
Apr 04, 2017 | Audio Players & Recorders
Polk sub DSW2000 fuse blows each time you switch it on.... How do i fix it or any circuit drawings or service help....Thanks for all replies
Sounds like your fuse is rated too low, try a heavier fuse or search Retrevo Manuals.com and you may find a manual.
Dec 16, 2013 | Polk Audio PSW10 Subwoofer
My polk psw 10 keeps blowing the 2a fuse as soon as i plug it in ? Any solution besides the dump ?
Unplug the power, get inside it and disconnect either lead to the driver; stand back and plug it in to see if that helps. If so, the woofer is shorted and can be replaced failry cheaply. Otherwise it's probably more complicated and expensive for a hands-on tech to isolate the electrical problem.
Dec 23, 2010 | Polk Audio Audio Players & Recorders
Internal fuse keeps blowing out.
Suspect an overload in either the power section or the main amp semi-conductor. Look for parts that are damaged or get hot.
Mar 05, 2010 | Polk Audio PSW10 Subwoofer
Blew a fuse what kind dose it take is it a slow blow fuse or fast blow one,i took out the old fuse and it reads le.3a/250v is it a 3a or .3a
It is a 3A/250V fuse, also known as a 6A/125V fuse.
Power amps generally have slow blow fuses.
If this is helpful, please be sure to hit the "Thumbs-Up" for me!
Jan 24, 2010 | Polk Audio PSW202 Subwoofer
Polk Audio PSW10 electrical board smoking
I should just replace the parts that were burning, it will cost a lot less.
Jan 15, 2010 | Polk Audio PSW10 Subwoofer
Jan 04, 2009 | Polk Audio PSW10 Subwoofer
PSW 10 Not working
Your 2A 250v slow-blow fuse is blown, located under the back pannel. Mine just did the same thing. Problem is the problem with my PSW10 goes beyond the fuse. I have contacted Polk tech support to help me trouble shoot.
Sep 06, 2008 | Polk Audio PSW10 Subwoofer
Polk Audio PSW10 Subwoofer Logo
569 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ed_dantes
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
