Question about Olevia LT42HVi 42 in. LCD Television
We can't turn on the TV. We[ve tried the remote & manual controls & have unplugged it & plugged it back in using both the surge protector and wall outlets to no avail... Any suggestions?
  • Olevia Master
  • 8,457 Answers
The power LED indication light flashes or totally dead?The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacemrnt.
Posted on Oct 17, 2010
  • Ondi Oct 17, 2010
    Last night the power indication light (the blue light that normally goes off when the power is turned on) would go off when the power was turned on. It wouldn't come back on unless the reset switch was used or the set was unplugged and plugged back in. This morning the power indication light will NOT go off when I try to turn the TV on. It will only go off if I unplug the set or turn off the reset switch on the back of the TV....Does that extra info help? -Ondi
I have a 22" Polaroid tv. The remote that came with the tv has stopped working except to turn it on. I've tried unplugging the tv and when i plug it back in the remote will work until i tu
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Dec 15, 2014 | Polaroid TDAC-02212 22 in. LCD HDTV/DVD...
HDMI inputs not working
Find the manual for your TV. Find how to reset the TV. There may have been a power surge that is not letting the HDMI ports work. A hard reset should work. If you can't find how to do this, unplugging it, and waiting a minute, then plugging back in could be an easy fix.
Oct 23, 2014 | Emerson Used Original LC320EM2F Remote...
LN55C750R2FXZA Samsung LCD
What your describing is symptoms of a power surge, Many LCD Tv's are sensative to Slight fluctuation in power during rain, thunder and lightning storms, i myself was happily watching Tv through such a storm at one time, and when i went to bed the TV would not respond remotely or manually, i also disconnected the power from the wall waited for the ready light to disolve and try to turn on, unfortunatley the damage was done, a Tv Repair was nessecary and since then i now use a belkin power surge protector board for my TV and appliances......one question to you is i would guarantee you do not use a surge protection my friend......and your set will need a Tv Repair, it is not major as what is neccesary is a firmware dump on the internal memory and replace the BIOS Battery as well.
Aug 17, 2014 | Samsung UN55B8000 55 in. LCD HDTV
The remote will not turn on the Bose System intermitently.Need to turn the power off for TV & Bose unit & then back on for it to work.
If your system is plugged into a surge protecter, the Bose service guy told me that sometimes the Bose system detects a surge and automatically shuts down. Unplug the system for 5 minutes and then plug back in. This works because it happened to my system. I called Bose and this is what I was told. It worked!
Dec 27, 2012 | Bose Solo TV sound system - Black
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
32 '' CRT won't turn on afer power surge
Follow these steps to troubleshoot the television not turning on:
Make sure the AC power cord is connected securely to a working wall outlet.
NOTE: If the television is plugged into a power strip or surge protector, unplug it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
Press the POWER button on the television.
Press the POWER button on the remote control that was supplied with the television.
NOTE: If the television turns on and off using the POWER button on the television but does not respond to the POWER button on the remote control, troubleshoot the remote control.
Unplug the television power cord from the electrical outlet for 30 seconds.
Plug the power cord back into a known working electrical outlet.
Attempt to turn on the television.
IMPORTANT for the following models only:
KDF-E42A10
KDF-E50A10
KDL-V26XBR1
KDL-V32XBR1
KDL-V40XBR1
Unplugging the above television models from the electrical outlet may only be a temporary fix. The problem may reoccur after several months of use. To completely resolve the issue, a software update is available.
For all other models, service will be required if the troubleshooting steps do not resolve the issue.
Aug 01, 2009 | Televison & Video
Hitachi 60UX58B will not turn on
I think there could have been a power surge... ask the repairman if the power supply is blown. :)
Jun 18, 2008 | Hitachi 60UX58B 60" Rear Projection...
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
Olevia LT42HVi 42 in. LCD Television Logo
931 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
