I just bought a aiwa turntable & stereo at yard sale. the old lady said she never used it but yet the turntable will not turn. i've looked over the manual and can't find any troubleshooting. can you help?
Hi Denise, I am in the consumer electronics repair industry. It may be as simple as this... Lift up the MAT on the turn table. This is the black rubber covering that you place the record on. Look through the holes in the plastic turntable (rotate if necessary) until you see the motor/pulley shaft sticking up (brass color). The turntable belt may have dislodged from this pulley. If you see the black flat rubber belt near here, just put it around the pulley again. Make sure it is not twisted and sits flat. Spin table by hand to be sure it is seated properly.
Now you may have to remove the plastic turntable itself if you can't see the belt right away. In this case, remove the C-clip with a flat screwdriver (be sure not to lose it) from the record center post. Lift the turntable plate up shaft. Check to see if the belt is still partially around the plate. You may be able to just see enough to wrap the belt around the motor pulley now. If you need to take the plate off completely, then just place the belt first around the groove on the plate and finese the belt around the motor pulley. Now seat the plate, replace the C-clip and place the MAT back on and it should be good to go.
I had this same problem on a new turntable I got for free. Good luck : )
Posted on Oct 03, 2011
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
How to replace stylus on AIWA stereo turtable
the old stylus snaps off. pull evenly straight out. The new one snaps on in its place. Do not touch the needle as it is easily damaged.
Jul 02, 2014 | Aiwa PX-E860 Turntable
THE PLASTIC COVER OR LID IS BROKEN FROM MY AIWA PX-E860 TURNTABLE WHERE CAN I BUY IT. SILVIA DE ALBA
I don't think you can find this part easily and new and honestly it doesn't worth it.
I would suggest to go for this or something similar
Aiwa Stereo Full Automatic PX E860 Turntable System
Feb 12, 2014 | Aiwa PX-E860 Turntable
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Apr 08, 2013 | Audio Players & Recorders
Speakers for aiwa PX- E90HE stereo turntable
you also need an amp or reciever, just hooking up speakers to this turntable will not work
Mar 08, 2013 | Audio Players & Recorders
Can you still get the px-e860 turntable? The one I have won't make any sound thru the speakers
Judging by my own experiences with hifi gear on eBay there is little on the face of the planet that ever really becomes UNavailable.
Wouldn't an attempt to resolve the issue work, too?
Describe your setup (preamp, amp, whatever) and if it has ever or never worked.
This unit can work through its own preamp with any audio equipment or with old-school gear already having an internal Phono Preamp. There's a switch to select which one.
Apr 08, 2010 | Aiwa PX-E860 Turntable
Connecting a turn table to a micro stereo system
You will need the following to connect this to that system:
1) Phono Pre-amp
2) 3.5mm to RCA adapter or 3.5mm 'Y' cable to RCA
3) Turntable
Your turntable will connect to the Phono Pre-Amp input. This pre-amp will also have an output. This output is RCA, from here you connect to your system using the 3.5mm adapter or cable.
That's it.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Aug 07, 2008 | Audio Players & Recorders
Manual for stereo system
I need to know the product # in order to try to locate a manual.
Oct 29, 2007 | Sony CMT-EP404 Shelf System
105 people viewed this question
 Grubhead
Grubhead
