Question about Apple iPod MA446LL/A MP3 Player
XBOX360 My XBOX 360 will not play. When i insert a disk the power button flashes red.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey 2hitz,
According to information provided by the manufacturer, when the power supply light is red this can typically mean that the XBox 360's external power supply (AC adaptor) has encountered a problem and may need to be repaired or replaced. Most problems encountered are typically limited to an issue where the system has overheated or there is too much voltage/electrical current for the power supply to handle.
I'd first suggest checking to see if the AC adaptor is properly connected to your XBox 360 or is warm to the touch. If the adaptor is hot, you may wish to unplug the adaptor for several hours to cool before reconnecting it to your XBox 360. Even if it is fairly cool, you may still want to see if disconnecting and reconnecting the adaptor resolves the issue. If the power light changes from red to an orange hue once you do, this can mean that the power supply may not have been securely attached and the unit is now in standby mode.
Next, if you have access to a second power adaptor, you may want to see if switching adaptors resolves the issue instead. If the XBox 360 goes into standby mode with a different adaptor plugged in but not the original, then the original adaptor may be defective and be in need of replacement.
Please keep in mind however, that if the lights around the power indicator light are also flashing red this may be a sign of an entirely different hardware problem. If you are seeing any of the lights in the outer ring light up, you may want to take note of which ones (and how many) are lighting up at any given time. Typically one flashing red light in the outer ring may indicate a hard drive problem, two red lights may indicate the XBox 360 itself has overheated, three red lights mean that the unit requires service/repairs, and four red lights mean that your audio-video (AV) cable isn't securely connected.
If you're still not quite sure how to proceed, you can always visit Microsoft's knowledge base website for more information and suggestions by using the link I've provided below:
http://support.microsoft.com/
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 04, 2008
I switched disk drive from 360 to 360 and now it wont play dvds someone please help!!
the issue is with in the swapping. The system inbedded a security code that is only identify by that single xbox360. In order for your system to recongize your disk drive in another xbox360 is if 1. the diskdrive is replica of the one swaped then only the chip under the drive is needed from that system or 2. flashing the disk drive. **BOTH ARE ILLEGAL**
you can manage either one by googling flashing xbox360 diskdrive ______ <--- the type of diskdrive you swaped out.
Mar 17, 2011 | Microsoft Xbox 360 Console
I have a red light on my xbox and it told me to look for consumer support. what do i do
How many lights are blinking??
Two blinking red light's on the power button means that your console has insufficient ventilation. The red light will continue flashing until the console cools down.
Let your console cool
  1. Turn off your console.
  2. Let your console cool for one hour.
  3. Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
http://support.xbox.com/en-us/pages/xbox-360/troubleshoot/hardware/flashing-lights-wizard.aspx
Feb 11, 2011 | Computers & Internet
The power button flashes red
http://llamma.com/xbox360/repair/xbox-360-repair.htm
Mar 07, 2010 | Microsoft Xbox 360 Console
Ac adaptor blinking orange. Xbox360 won't power up.
An orange light is illuminated on the power supply for one of the following reasons:
  • The console is turned off.
  • The power supply is disconnected from the console.
  • The power supply cord is not fully inserted into the power socket of the console.
  • The power supply is faulty.
  • The console is faulty. (The console might be faulty if it does not turn on when the power supply light is orange.)
Step 1: Try to connect and then disconnect the power supply
loadTOCNode(2, 'whattotry'); Follow these steps to connect and then disconnect the power supply:
  1. Turn off the Xbox 360 console.
  2. Disconnect the cord that connects the power supply to the console.
  3. Reconnect all the cords, and then try to turn on the console.
if after this also your console does not power up then you need to check if you are seeing any flashing red lights on the power button of Xbox 360, if you see the red flashing lights then you would have to get your power adaptor replaced by calling up MS Customer Support.
If you do not see flashing red lights on the console power button in that case the console itself would have to be send for repairs
Please do rate my solution, Wish you Happy Holidays and Happy Gaming
Regards
KreativeGeek
Dec 29, 2009 | Microsoft Xbox 360 Console
Why do my xbox360 says play dvd when i inserted my 360 game disc
not much u can do send it in no warrenty, no problem over heat the thing intill u get three red lights and make sure it has red lights and microsoft will fix it for free
Aug 16, 2009 | Microsoft Xbox 360 Console
Flashing red lights
Your xbox might be overheating. Read http://support.xbox.com/support/en/us/xbox360/kb.aspx?ID=907533&lcid=1033&category=hardware for more information.
Apr 10, 2009 | Microsoft Xbox 360 Console
Xbox does not read games
you need to give the 360 a sacrafice so it will work again,you know brake a ps3 and give it to the 360.that will make it happy
Mar 14, 2009 | Microsoft Xbox 360 Elite Console - Black
Xbox 360
All dvd drives in an xbox360 are married to the motherboard. The new dvd drive needs to be flashed with the bin from the old drive in order for it to play games. We can do this for you if your interested email us xbox360fixer@verizon.net
Jan 26, 2009 | Microsoft Xbox 360 Console
Xbox Does not play original games
Error Codes XBOX360
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Feb 25, 2008 | Microsoft Xbox 360 Console
Apple iPod MA446LL/A MP3 Player Logo
94 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
