Question about Sharp Office Equipment & Supplies
There is a "code" of H4 appearing on the "window" of the AL 1540CS.. Can you advise me how to correct the problem?
  • havermar46 Oct 17, 2010
    I followed your instructions perfectly and the H4 blinking never stopped blinking - i.e. nothing happened I did it several t imes and even unlugged the copier and tried it serveral times more and nothing stopped the H4 frin continuing to blink steadily. What now?
  • 10,515 Answers
H4 indicates fault with the fuser, fuser temperature is low.
Sometimes it can be reset by technician and works fine or you should replace the fuser lamp.
TRY out this to reset, as per the manual,
PRESS: Clear - exposure - clear - exposure = the LED display will turn off.
PRESS: # of copy keys until you have 14 displayed.
PRESS: Enter.
If the problem persists, you need to get this repaired.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 17, 2010
  • Sharp Master
  • 12,061 Answers
It is the fuser, but sometimes it is just a false code. to reset enter buttons clr, exposure, clr, exposure, the display will blank, enter 14, press prnt button, then clr several times to get out and thats it.
To clear this code do the following.-
PRESS: Enter.
Error code H 4 Sharp model AL 1540CS
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Thanks
Oct 24, 2011 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL 1540 cs Code CH What is the code and how can I fix it. A new toner cartridge was installed last night.
Check the new unit is correctly seated and open and close all covers on the printer until it clears.
The CH Code is for an open cover but maybe to do with the cartridge not being seated correctly.
May 04, 2011 | Sharp AL-1540CS All-In-One Laser Printer
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
What does 4 H indicate?
When your copier voltage is abnormal then heater lamp is not on properly.So indicate H4.When H4 signal is blinking you must reset this code or error.
press c button press Photo/Exposure button again C Photo.(C>Photo>C>Photo) display blank press copy quantity button 14 press print key /Start key machine will be ready.
All are hopes fix
Dec 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Sharp copier model AL 1540cs gives a code H4
H-4 is usually a fuser low temp indicater. Use simulation 5-2 to check fuser lamp. If lamp checks good move on to next problem (it will light up..trick door switch so you can see the light from end of heater unit) The thermister could be dirty or defective(fuser must be dismantled to clean)
Mar 08, 2009 | Sharp Office Equipment & Supplies
Code CH on Sharp copier
CH code on a Sharp usually means the front door or a side door is not completely shut. Try opening and closing every exterior door until the code goes away. If the CH is flashing, it could mean either an optical or a heat roller fuse might have blown. Have you recently replaced any supplies?
Feb 27, 2009 | Sharp AL-1540CS All-In-One Laser Printer
I have 2 model al-1540cs copiers that are producing blank copies. The scanner doesn't seem to be moving and is in the unlocked position. I am getting no error messages, the paper is facing in the right...
When [L1-00] appears, the scan head
locking switch is locked. Turn off the
power, release the scan head locking
switch, WAIT 10 SECONDS and turn the power back on.
Dec 04, 2008 | Sharp AL-1540CS All-In-One Laser Printer
AL-1540CS error code F5
i have al-1540cs and it if flashing H then 4
Apr 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL- 1540cs
On my SHARP AL-1540CS printer 4 and H blinks alternately and none of the buttons except power is working.
Oct 19, 2007 | Sharp AL 1215 Black and White Copier
27 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
