Question about GE 5.8 Cu. Ft. 2-Cycle Extra-Large Capacity Gas Dryer - White-on-White
Dryer cuts off after running for a while. after about 10 minutes you can start it again.
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 17, 2010
What is causing my electric dryer to stop running after 5-10 minutes
I presume that after it has "cooled" it starts and runs again? If so, the air circulation, perhaps the vent is clogged and needs cleaning. The high heat protection device is "cutting out" when the temperature gets too high to prevent disasters.
Apr 10, 2015 | Siemens WTXD5300US Electric Dryer
Creda TCR14 runs for 10 minutes and stops - will only go if hold button in !! Leave for half hour and it will go again - seem oviously like thermal cut out problem, ut where it it situated ? Please
heatman101
Sep 16, 2010 | Dryers
Unit begins to work correctly and after it runs a little and gets hot it cuts off. After 5 or 10 minutes it begins to run again. Does this often. Any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 14, 2010 | Whirlpool GEQ8811L Electric Dryer
My dryer a Whirlpool. will run for about 10 to 20 minutes, then cuts off. After about 10 to 20 minutes, I can start the dryer again (push start button) and it will run for another 10-20 minutes. ....This...
there is a hi and a low tempreture sensor best to check those for continuity first when the dryer heats up and gets to hot the hi will turn off the heater where as when the low gets to cool it will turn it back on
hope this helps
Apr 30, 2010 | Whirlpool LER4634J Electric Dryer
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Kenmore 90 series gas dryer
possible motor overheat ..if unit has a lot of lint or has had vent problems now or in past lint may have accumilated around motor and caused it to overheat and shut off.. probably to late to save motor
Sep 29, 2008 | Kenmore 73952 Gas Dryer
GE 5.8 Cu. Ft. 2-Cycle Extra-Large Capacity Gas Dryer - White-on-White Logo
56 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
