Question about Garmin StreetPilot C330 GPS Receiver
Garmin c330 no power
I charged my garmin for several hours on my computer and it shows charging when i disconnect and try to turn on it does not come on
  • bigbreak1950 Jun 09, 2008
    have all ready tried the reset button , still will not come on unless plugged into a power source
    when i plug it in it shows charging and i can turn it on and off while plugged in. when plugged in it works fine, i have purchased a car plug and when plugged in it works great but when unplugged it goes dead. this is a reasent purchase and is a refurbished c330
  • 3,037 Answers
You can try taking off the front cover panel and then press the reset button that is under there. Let me know how that works out for you and if it still isn't working we can go from there. good luck and please let me know of any further questions you may have as I am more than willing to help.
Posted on Jun 03, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • Benjamin Patri
    Benjamin Patri Jun 09, 2008
    When you plug it in, does it turn on by itself or can you turn it on yourself. Possibly there is a loose connection on the device. Also, does it work well when plugged in?
  • Benjamin Patri
    Benjamin Patri Jun 10, 2008
    If it is refurbished, it is possible that either the battery is bad or not even charging. I would try putting a different battery in and seeing if that makes it turn on. Make sure the battery is charged before hand. Also, what the problem may be is a loose connection from the battery to the board. This will require opening the device to check but possibly a wire or piece of metal broke or cracked.
  • 156 Answers
Try resetting the unit. this most often does the trick..
    Genius:
  • 1,665 Answers
Try changing battery and see again
2 Suggested Answers
  • 174 Answers
SOURCE: no power to garmin c330
Does the unit turns on while pluged into the computer? If the answer is yes, then you will need to replace the battery. The battery is not taking a charge.
Posted on Jun 05, 2008
Brand new Garmin Nuvi 1490 T out of the box. How do I charge it? The only devices in box were a car charger (my commute is 5 minutes daily) and a USB connector? Should I just plug the USB into my computer?...
Garmin satnavs come with a charge out of the box.
In some cases your device may have lost a charge during shelf life. In this case you can charge these units in three ways:
  1. Place unit on computer with USB cable for approximately 8-12 hours
  2. Place unit on Garmin specified AC adaptor for approximately 4-6 hours
  3. Place unit on 12V vehicle adaptor for approximately 4-6 hours.
Some cars continue to supply power to the cigarette lighter socket when turned off and others don't. If yours doesn't you can charge it from your computer. There's no indicator to show that it's charging or when it's charged. However when you disconnect the satnav from the computer and turn it on there's a battery state indicator which shows if it's fully charged or not.
Aug 16, 2010 | Garmin nuvi 1490T GPS Receiver
StreetPilot C330 (010-00401-10) GPS Receiver: I just recently purchased a Garmin GPS system for ...
If there are no power points in your vehicle, you might have to purchase a battery-operated powerpack and plug the GPS into that via a USB/AC adapter.
May 18, 2010 | Garmin StreetPilot C330 GPS Receiver
Shuts off, won't charge battery
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 26, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin won't turn on or charge.
Mar 23, 2009 | Garmin StreetPilot C330 GPS Receiver
I turned it on and it lit up and then completely died
Question: Why won't my StreetPilot c3xx power on?
Found on the Garmin web site --> Answer: If your StreetPilot does not power on, or if it turns on then turns off, you can troubleshoot the problem by resetting or charging the unit. The reset is a "soft" reset that you can perform in the car; it restores power to the unit, but it does not remove data.
To reset the unit:
  1. Place the unit in the cradle and roll it backwards slightly to lock it in place.
  2. With the key in the car ignition, turn on the unit or put it in accessory mode.
  3. On the face plate of the unit, put your thumb nail in the groove under the Garmin logo and gently pull off the face plate.
  4. With the face plate removed, press the reset button on the right side.
  5. Turn the unit back on. If the unit still doesn't power on, you may need to charge it.
To charge the unit:
  1. Using the provided USB cable, connect the device to the computer.
  2. Reset the unit (following instructions above).
  3. Keep the device connected to the computer and allow it to charge overnight (7-8 hours).
  4. After charging, unplug the unit and power it on.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 03/10/2008
Oct 05, 2008 | Garmin StreetPilot C330 GPS Receiver
No power to garmin c330
Jun 03, 2008 | Garmin StreetPilot C330 GPS Receiver
How to charge garmin c330 gps from computer
The unit came with a USB cable. Plug this into the GPS (when it is turned off) and it will come on and the unit will charge while showing an image of the GPS connected to a computer tower.
Mar 19, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin wont stay on
How did you charge the unit? If you have not done so, try charging in on the computer for a few hours. Sometimes this can help.
Nov 24, 2007 | Garmin StreetPilot C330 GPS Receiver
Power On problem
Have you tried charging the unit on the computer? If not, charge it about 10 hours on the computer. This can sometimes help.
Oct 29, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
