Question about Mongoose Cycling
My son has a 20" Mongoose Outer Limit Freestyle bike. The tire is flat and can not be aired up. It seems there may be a problem with the valve stem. Any suggestions on repairing the valve stem? Should I just return to Wal-Mart and buy an inner tube for the bike?
  • 186 Answers
You cannot fix a valve stem.sorry chuck it out or return for a new one
Posted on Oct 17, 2010
How to fix the back tire
Those are ball bearings. If they are out of the wheel you have a complex problem and repair. I suggest you take the wheel to your local bike shop.
Sep 14, 2014 | Mongoose 20-Inch Gravity Games BMX...
What is the crank bearing size??
Almost all Mongoose models use the standard BSA 68.
I would write a question to them at:
http://mongoosebikes.net/mongoose-bmx-bike/20-mongoose-mode-270-v2-freestyle-bmx-bike/
This bearing should not fail during the normal life of the bicycle, unless the rider weight is over 80 Kg.
Jun 10, 2014 | Mongoose 20" Mode 270 Boys Freestyle Bike
Who do I put the rear wheel back on my mongoose bike
raise the back of the bike and put the wheel between the rear stays place the chain on the freewheel, and pull the wheel back and
then just tighten the wheel nuts.
Jul 26, 2013 | Mongoose 20-Inch Gravity Games BMX...
How to install front tire of mongoose bmx
Remove wheels, remove valve stem from innertube. remove tire by getting tire edge over rim. reinstall in opposite direction. If this seems difficult consult local bike shop for assistance
Dec 28, 2012 | Freestyle Mongoose Bmx & Owners Manual -...
I am wondering where I can order a back wheel for the mongoose 20 inch outer limit boys bike. Accidently got run over and is very bent. Thank you deb
Any Mongoose dealer or bicycle shop should be able to handle that or just web search for a 20" BMX wheel. It doesn't appear to be unique.
Sep 13, 2011 | Mongoose Outer Limit Boys Bicycle Pad Set...
I took the pegs off my son's mongoose outer liit freestyle bike (20") and now cannot figure out how to put them back on. I am not sure what to do with the silver washer?????
The silver washer will go between the frame of the bike and the peg. Then the nut for the wheel bolt will go into the peg and screw on from the inside of the peg. Unless they are solid pegs in which case you will put the washer on first still and then screw the peg on as if it were the nut itself.
Aug 20, 2011 | Mongoose 20-Inch Gravity Games BMX...
How do you remove the front wheel of a 20" Outer Limit freestyle Mongoose bike?
if i remember correctly it is a 15 mm socket for a ratchet that is the tool that i use at the shop
Jul 10, 2011 | Freestyle Mongoose Bmx & Owners Manual -...
My brakes are squeezing my tire on my 20'' mongoose outer limits bike and i can not figure out how to untighten them.
Try and move the whole wheel back a little and see if that helps. if not adjust the brake pads untiill the contact the rim and not the tire
May 20, 2011 | Mongoose Outer Limit Bmx Freestyle Bike...
How to replace a crank on a mongoose orbit 2008/9 series. My crank was bent from trying to do tricks so I need to fix my bike I never did this before so I need help
take the pedal off the opposite side that the chain is on the there should be two bolts turn the first one towards the back tire and take the washer out and use a flat head screwdriver to tae the second ne out the same way pull the first set of bearings out then pull it through the frame it might be a little hard but it will come out make sure you take the chain of the sprocket then put everything on the same way
Nov 24, 2009 | Mongoose 20-Inch Gravity Games BMX...
Wheel does not turn when peadalled
needs a new sprocket on the wheel the teeth inside are worn
Oct 12, 2009 | Mongoose 20-Inch Gravity Games BMX...
Cycling Logo
240 people viewed this question
Top Mongoose Cycling Experts
M.R.
M.R.
Level 1 Expert
WTF Chuck.....
WTF Chuck.....
Roger Paull III
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
