Question about GE Food Processors
I have an old GE Food Processor Model FP-1/4200. I think the belt that turns the fluted drive wheel is broken but I can't figure out how to get into the base to check. How do you open this thing? Thanks.
SOURCE: parts
I found a web site that seems to have the part. I was looking for the same item. I just put in FP1445 (Processor model number) in the search field and it showed all the parts available. There are no images though so I hope it fits when I get it. Here's the web site.
http://estore.fox-international.com/b&d.asp
Posted on Jan 28, 2008
SOURCE: part for old food processor
Anyone want any of this? The motor doesn't work. And, the bottom of the container is cracked.
Posted on Jan 23, 2009
  • 24 Answers
SOURCE: GE Food processor knife blade, bowl and cover .
plz con-022-23095757 / 23051554
Posted on Feb 03, 2009
SOURCE: Broken processing bowl to food processor
I have replacement parts available for the Technque CETOFP263, will only charge nominal fee plus shipping costs. email me or post to ebay seller churkey123.
Posted on Mar 16, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Posted on Mar 17, 2009
My Hamilton Beach Food processor model # 702-1 has a BROKEN plastic gear that attaches to the motor drive shaft (it threads onto the shaft). It meshes with another plastic gear that turns the spindle that...
my suggestion is that watever spare part u replace, get it replaced by the original manufacturer to avoid future problems. take it to the shop you have bought it from, ask them where u can get one. they may help u better with contacting the manufacturer. i know its time consuming! good luck!!
Oct 14, 2009 | Food Processors
Need new gaskets
You might try this location:
http://www.appliancepartspros.com/partsearch/
However, the model number isn't listed.
Look at the model sticker.
Sep 29, 2009 | GE Food Processor
GE Food Processor Supreme cutting blade
Sue, I have one the same model number and I cannot use it since the top is broken. I can send picture of the blades if you are interested. Please email me at egnieves@coqui.net.
Sep 05, 2009 | GE Food Processors
Need an o-ring for an old GE food processor cat. # D5FP1.
I have had great luck at Ace Hardwares and Lowe's. They have drawers of O rings. Take your part with you, and try them untill it fits!
Regards --W/D--
Jul 20, 2009 | GE Food Processor
Replace Rubber 0 Ring for GE Food Processor Inside Diameter 2 6/8
I decided to trash my 19 year old GE Food Processor that needs a new gasget and puchase another.
Thanks for your interest.
Samella 124
Apr 09, 2009 | GE Food Processor
Hamilton Beach Food Processor Type FP03 Model 702R Series
I just ordered a drive belt from https://www.goodmans.net/ for Hamilton Beach/Proctor Silex Food Processor Type: FP03 Model: 702R for $7.99 + shipping.
Sep 06, 2008 | Black & Decker FP1400 Quick N Easy Plus...
GE food processor, Model 106622
I THINK I JUST SAW A NUMBER YOU COULD CALL I HAVE THE SAME PROBLEM
I REALIZE THIS IS A BIT LATE IN HELPING YOU!
1-877-207-0923 MODEL IS DISCONTINUED BUT THEY SHOULD BE ABLE TO SEND YOU ONE!!
NANA IN GA.
Jul 07, 2008 | GE 106622F Food Processor
Food Processors Logo
155 people viewed this question
Top GE Food Processors Experts
eyecam
esspeajay
Level 1 Expert
Are you a GE Food Processor Expert? Answer questions, earn points and help others
