Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I don't have the manual to re-program my keyless entry pad and cannot use it. The previous owner did not keep the manual and on occasion, he comes back and goes into the garage. He is in his mid 80's and has demencia or something and moved down the street to his daughter's, so I don't complain. I just want to change the numbers for entry. The numbers on the remote are: IC:2666a - 102 621, 139.18791B, FCC ID: HBW1255. These are the numbers on the remote. I cannot climb up to get the model number off of the unit, but is only 3 or 4 years old. Thank you, Debbie - October 16, 2010.
    President:
  • 3,197 Answers
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
You may need help with this if you cannot get up on a small ladder.
Posted on Oct 18, 2010
How do you prgram remote keyless entry
Here are the instructions from the factory service manual:
1. Enter 5-digit permanent entry code into the keyless entry keypad.
2. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then
unlock confirming you are in programming mode.
3. Press any button on first Keyless Remote within 5 seconds of pressing the 1/2 button. Locks will
cycle to indicate succesful programming.
4. If you are programming more than one Keyless Remote (Including any exsiting remotes) Press
any button on second keyless remote within 5 seconds of previous remote. Locks will cycle again
to indicate succesfull programming. (If the keypad light goes out before all remotes are
programmed the entire process must be repeated).
5. Press the 7/8 and the 9/0 buttons simultaneously on the keypad to exit program mode.
Sep 14, 2011 | 1995 Ford Crown Victoria
Purchased a 2007 MKZ and there was no owner's card to get the keyless lock code. How can I get it so I can set my doors?
The keyless entry code should be printed on a label by the fuse box. I have attached a picture of where you should find the label SECTION 501-14: Handles, Locks, Latches and Entry Systems 2007 Fusion/Milan/MKZ Workshop Manual GENERAL PROCEDURES Procedure revision date: 07/31/2006 Keyless Entry Keypad Code Programming adobe.gif Printable View (109 KB) NOTE: To associate a memory configuration to a personal entry code, refer to the Owner's Literature.
  1. Enter the permanent factory keyless entry keypad code.
  1. NOTE: Holding the 1/2 button for more than 2 seconds after activation erases all the customer codes. The existing code does not need to be erased to program a new code.
    Press the 1/2 button within 5 seconds to activate the programming mode.
  1. Within 5 seconds, enter the new 5-digit keyless entry keypad code. The doors lock and unlock to confirm the new code is programmed.
2010&c18=modelyear&c20=n996353&c35=wsm%2ckeyless%20entry%20keypad%20code%20programming%2cs7s%2c501-14%2cgeneral%20procedures&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=428&ct=lan&hp=n&[aqe] ddll111_2.jpg
Mar 10, 2011 | Lincoln MKZ Cars & Trucks
How do i reprogram keyless entry codes
door pad keyless codes?
in owner manual, enter permanent code and then press "1" and enter personal code, then press "1" again. Then both codes will work.
If you don't have manual, go to Motorcraft.com and click on technical resources and click on your year owner manual.
Each vehicle equipped with a keyless entry keypad is programmed with a five-digit entry code. This code is provided to the customer through a wallet card in the Owner Literature package. In addition, this code is available through a diagnostic tool and is also printed on the vehicle security module label. When entering codes each digit must be entered within five seconds of the previous button press.
Programming/Erasing Personal Code
A unique personal five-digit code can be programmed by following these steps:
  1. Enter the factory set five-digit code (the keypad will illuminate when pressed).
  1. Press 1/2 within five seconds of Step 1.
  1. Enter the unique five-digit code.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it will simply overwrite the previous personal code. To erase a personal code, carry out the following procedure:
  1. Enter factory set five-digit code.
  1. Press 7/8 and 9/0 at the same time within five seconds of Step 2.
The system will now only respond to the factory set code.
Anti-Scan Feature
To provide added security, the keyless entry pad is disabled for one minute after 35 button presses without a valid entry code being entered. The keypad will flash during this one-minute mode with all functionality disabled except for 7/8 and 9/0 still being allowed to lock the vehicle.
Anti-Scan will be turned off after any of the following events:
  • one minute of keypad inactivity
  • the keyless entry remote transmitter UNLOCK button is pressed
  • the ignition is turned to the ON position.
Unlocking the Doors with the Keyless Entry Keypad System
To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will illuminate.
To unlock all doors, enter either the factory set code or the personal code (driver door unlocks) and press the 3/4 control within five seconds.
Locking the Doors with the Keyless Entry Keypad System
It is not necessary to enter the factory set or personal code prior to locking all doors. To lock all doors, press the 7/8 and 9/0 controls at the same time.
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical or electrical damage.
Dec 01, 2009 | 2004 Ford F350
Program fob/reset keyless entry pad 95 cougar
If you open trunk and look on inside of trunk where hinge bolts are you will see code numbers . Owners manual will tell you how.
Jul 21, 2009 | 1995 Mercury Cougar
Key Pad Entry does not work
does the key pad light when you press a button at night? If yes, the fuse is ok.
Do you have the plastic card with the permanent code in your owner manual packet? If yes, tryit.
report back.
Keyless Entry The keyless entry keypad is hardwired to the GEM. The GEM interprets the inputs from the keyless entry keypad and then controls the associated operation. The keyless entry keypad will be illuminated for five seconds when any button is pressed. Additionally, it will request the illuminated entry feature to turn the courtesy lamps on. If a lock all doors code is entered, the illumination will turn off, as well as request the illuminated entry feature to turn off the courtesy lamps. When pressed, the keyless entry keypad supplies the ground signal to the GEM or the GEM receives a signal from the keyless entry remote transmitter. Then the GEM outputs a ground signal to the appropriate lock or unlock relay which supplies the power to the actuator to lock or unlocks all doors, including the luggage compartment. The keyless entry remote transmitter also unlocks the liftgate or activates the panic alarm by sending a signal to the GEM.
--------------------------------------------------------------- Visual Inspection Chart Mechanical Electrical
  • Keyless entry keypad
  • Keyless entry remote transmitter
  • Central junction box (CJB) Fuse F222 (20A)
  • Circuitry
  • Generic electronic module (GEM)
  • No communication with generic electronic module (GEM)
  • Generic electronic module.
  • Circuitry.
  • REFER to Section 419-10 .
Mar 08, 2009 | 2003 Ford Taurus
I can't find the keyless entry code for my 2004 ford freestar
The code is on the fuse box under the dash near the hood release. On my van there are two bar codes on a sticker attached to the fuse box. Under the first bar code, on the right side is the 5 digit code (bring your glasses the numbers are really small). After you get this code, just search the internet and there are plenty of forums on programing the keyless remote and also adding your own unique number to the key pad entry.
Good Luck
Mar 08, 2009 | 2004 Ford Freestar
Reprogram a keyless entry remote
Hello
this is how to program the remotes/keyless entry
How
  • Obtain all remote transmitters
  • enter the 5 digit permanent code into the keyless entry pad on the drivers door
  • Press the 1-2 switch on the keyless entry pad
  • Within 5 seconds
  • Press any button on the first remote transmitter
  • The doors should open then lock
  • Within 5 seconds
  • press any button on the second & third remote
  • within 5 seconds for each remote
  • to exit programming
  • simultanionusly press 7-8 & 9-0 switchs on the key pad or wait more then 7.5 seconds
NOTE
The 5 digit permanent code is located in one of the following places
  1. On the owners warranty card
  2. On the label on the inside the trunk/ boot
  3. On the owners code card
  4. On the centrel locking control module located in the drivers door
  5. In the PCM ford can get this for about $25.00
I hope this help
Regards Paul
www.limotec.co.uk
Jan 13, 2009 | 1995 Lincoln Town Car
retrieving is probably not an option however if you know the factory code , you can add 1 personal code which in turn would erase any other personal codes . your owners manual should back this statement up . follow these steps >>>>>
The keyless entry touch pad can use two codes. The factory code and one
personal code .
To program your own personal code, select a 5 digit code that doesn't use 5 digits in
sequence or the same button 5 times.
Enter your factory code
Within 5 seconds press the 1/2 button
Within 5 seconds of pressing the 1/2 button, enter your 5 digit personal code,
pressing each digit within 5 seconds of the previous digit.
You can now use either code to operate the keypad
Jan 12, 2009 | 2003 Ford Expedition
2001 Mercury Sable Keyless Entry-Fuse
check this fuse first. I believe it's #30. Check with chart on fuse panel cover or in your owner manual.eb303fa.gif
Jan 10, 2009 | 2001 Mercury Sable
Keyless entry
I believe dealer has to re-program the new code.
Aug 29, 2008 | 2001 Ford Explorer Sport Trac
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,140 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
