Question about Whirlpool Dryers
Dryer stopped spinning - Whirlpool Dryers
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 17, 2010
  • Anonymous Oct 17, 2010
How do I stop my dryer from spinning?
Could be bad timer but check the timer knob first have seen them crack so they are not pointing in the right direction
Dec 09, 2015 | Dryers
How to fix dryer that will spin but not dry
STOPS MID CYCLE AS IF AROUND 20-30 MINUTES? IF SO U MAY HAVE BAD MOTOR WINDINGS? OH OH, CAN CHECK HEATING ELEMENT AND THERMOSTAS WITH A MULTIMETER FIRST
May 12, 2014 | Frigidaire AGQ6700F / AGQ6700FE Gas Dryer
Dryer will not stop spinning when door is closed
Good Morning Jeff,
I see that you are having trouble with your Frigidaire dryer, model# GLGQ2152ES, to stop spinning, even though all the lights are off. It could possibly be the different boards and sensors miscommunicating with each other. I suggest giving the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 2-3 minutes. When you turn the power back on, if the dryer is still spinning, without you wanting it to, I would suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
Mar 19, 2014 | Frigidaire GLGQ2152ES Gas Dryer
The dryer timer stopped working
Is that a temperature senor in the GE spacemaker Laundry dryer? My dryer stops spinning when it gets too hot. After it cools down, it will spin and dry again.
Jan 05, 2013 | GE WSM2700W Unitized Spacemaker Washer and...
Would a faulty switch interlock stop a dryer from heating?
no. It would stop it from spinning. Now if the dryer isn't spinning then obviously it wouldn't be heating, but if its spinning with no heat the interlock switch is not your problem.
Nov 15, 2012 | GE Dishwasher & Dryer Interlock Switch -...
Drum keeps spinning after dryer door is opened
What is the model number of the unit?
Nov 03, 2012 | Kenmore Dryers
Whirlpool gas dryer (LGR8648PW1) doesn't stop spinning in automatic mode.
More than likely a bad timer assembly. They are usually easy enough to replace if you have basic mechanical skills. The part can be ordered from repairclinic.com.
Jun 26, 2012 | Whirlpool Dryers
Doesn't spin freely, works for about half a cycle and stops spinning. won't turn back on or spin good until it cools for a few hours. then you might get another half cycle or so out of it.
open the dryer door and maunually spin the drum around. if it spins relatively easily, then it sounds like the drive motor is going bad. the windings open up and it stops. sounds like you need a new motor. it may be cheaper in the long run to get a new dryer
Oct 20, 2009 | Whirlpool Dryers
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Dryers Logo
49 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
