Question about IBM TP A20M PIII700MHZ 64MB 12GB 14.1"24X 3COM COMBO (26334WU) PC Notebook
About Hard Disk size for Laptop IBM A20m
Tech Support guy (from a PC Store, in Mexico) could not be sure if this laptop (A20m) would accept hard disk bigger than 40GB. Was he correct? I am confused.
  • 77law77 Nov 01, 2008
    I have installed my hard drive and am now trying to put my thinkpad A20 laptop back together. Is there an easy way to make sure all the connections go back together and there are 2 wires near the power plug that are labeled AUX and MAIN and I can't see anything that they should be connected to.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Yes, you can insert any size you want don't be belittle by the inorent poeple in sales stores they will tell anyone anything just to make a buck.... lala linda i would suggest trying an 80 g it will prombally will do what you need untill you learn more about computers ok lala linda
Posted on Jun 05, 2008
New hard disk problem
Unplug , remove battery, reseat the HDD, plug in, reboot. Is the HDD new? If no remove and test.
Mar 11, 2013 | Computers & Internet
Reseat hard drive
The hard drive can be removed and reconnected (reseating) by removing the screw/s on the bottom of the laptop. The hard drive compartment will have disk symbol. Open the laptop lid slightly before you slide out the hard drive. Insert the hard drive back into the laptop so it makes proper connection.replace the screw/s.
Boot up the laptop, if it does not boot up then power off and power up and press F1 to go into IBM BIOS setup - check to see if the hard disk is detected. If not then the hard disk is faulty and needs to be replaced then Windows needs to be installed on the new hard disk to get the laptop operating again.
May 30, 2012 | IBM Thinkpad T43/p Notebook
My laptop ibm thinkpad r52 my problam:-my upgread hard disk 160gb.but no sport to 160gb hard disk.my laptop on to message ERROR 2010:- The hard disk driver you have installed has not been qualified for use...
You are most likely trying to place a larger hard drive in the pc than the operating system will recognize. If you are using winXp you will need to slipstream the SP2 packet update into the CD...Could be with that R52 the bios will not support large disk volume either..
Aug 23, 2011 | Computers & Internet
When the hard desk in the laptop
Hi there Amr,
I would suggest doing the following:
1. Remove the hard disk (Turn off computer first)
2. Back up the hard disk using a hard disk back up device such as the one sold here
3. Purchase a new IBM hard disk and copy the data from the old one onto the new one
4. Insert new one into laptop and turn on laptop
5. Done!
Feb 20, 2011 | IBM ThinkPad T42 2373 Notebook
Does not boot error says no hard disk. I took out the old hard disk and installed a new one.
Make sure that the hard disk you put in is one supported in size by the bios of the laptop.
Jun 18, 2010 | IBM ThinkPad T20 2647 Notebook
Thinkpad T42 Hard Disk problem
Hello.
It seems the hard disk size will max out at 80GB with a 5,400 RPM speed according to IBM.
Im sorry to say that this means that it will not support a 120Gb hard drive.
Regards...
/Tech5508
Feb 14, 2009 | IBM ThinkPad T42 Notebook
IBM Thinkpad A20m model 2628
You can download the software known as Active boot disk. With this you can create a bootable cd to run a chkdsk with the f and r command to fix and recover errors on disk. you can also explore your comp and copy files to an external disk. If after the system boots normally after chkdsk you might have a problem with your HDD get it replaced before it crashes again
Jan 20, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
Error loading operating system
The Thinkpad T23 is old, and would not worth fixing. Save your money on a new one.
The problem with your laptop is that the hard disk or the disk controller has failed and therefore cannot find the operating system on the hard disk. The error message states that it can't see the operating system that is on the hard disk.
If the hard disk is the only thing that has failed then you can buy a new hard disk and install Windows operating system on it to get a working laptop again. You will also most likely need to download the device drivers (ie. video, audio, modem, LAN adapter etc.) from IBM to install after the Windows installation.
Try to borrow a 2.5" drive or get a cheap one from a computer market and fit it to your laptop to see if the BIOS can detect the hard drive. If it works then outlay some money to buy a decent size hard drive, no point wasting money if the laptop is faulty.
Dec 09, 2008 | IBM ThinkPad T23 Notebook
Change of Hard Disk
well,you can install any size you want and make sure you reboot from the cd rom when you reinstall the disc toshiba are hard to reboot sometimes unless you have the reboot disc .. lala linda
Jun 03, 2008 | IBM TP A20M PIII700MHZ 64MB 12GB 14.1"24X...
Computers & Internet Logo
66 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
