Question about Hitachi 60SBX78B 60" Rear Projection Television
My Hitachi 60sbx78b popped and then shut off. It will not power back on, I plug it up and it sounds like it is getting power, the green led lights come on for a few seconds and then they go off and the red led light begins to blink. How do I fix this or can I?
  • Hitachi Master
  • 3,459 Answers
On this model there is a common failure with some capacitors and fuses. Its a simple fix if you know which parts to use/avoid and how to do the repair. You can get complete instrucitons and parts for your model from www.TvRepairKits.com . Their kits include step by step color instruction guide as well as the correct parts to fix this issue.
Posted on Jan 22, 2011
Hitachi 60SBX78B No sound or Video
replace pico fuse E994 and capacitor C707. You have to disconect alot of wires and remove the screws holding the boards. you DON'T have to remove the large high voltage wires. You have to stand the board on it"s edge to unsolder the components from the back side of board. Good luck it worked fine for me. fcs0998@aol.com gene
Apr 27, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Tv won't turn on.
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Oct 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi Projection Color TV 60SBX78B
Hope this helps,
Oct 03, 2008 | Hitachi 60SBX78B 60" Rear Projection...
TV popped and turned off and won't come back on
Hope this helps,
Jun 27, 2008 | Hitachi 60UX58B 60" Rear Projection...
Tv will not power on
Hope this helps,
May 01, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi model #60SBX78B
The green led or lights on the board indicate some of the power supplies are working. The key is do you see any come on and then go out. this would indicate which part of the power supply is failing. also there are fuses in the set that do not look like your standard glass fuse. WARNING television generate lethal voltages that will hurt you. extreme care should be used.
Jan 18, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 60"(60sbx78b) Will not power on, fuse still good.
Matt, Hitachi`s have a series of green LED`s and one red LED on the main board, un-plug the tv for 30 seconds and then with the back cover removed plug the set back in and watch the led`s while someone else turns on the set, usually the led`s will temporarily light then one or more will immediately go out and then the rest will slowly go out and the red one will then start blinking, each led is a power supply indicator, 130 volt, 12 volt, 5 volt etcetera, find out which one(s) going out first and get back to me, BMW Rider
Jan 04, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Won't power up
Hope this helps,
Sep 17, 2007 | Hitachi 60UX58K 61 in. Rear Projection...
Hitachi 50ux58b
Hope this helps,
Jan 02, 2007 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
