Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
I have no sound from the speakers on my KV-27FS120....Please help?!
    President:
  • 2,992 Answers
Take a look at the back of the set. Some Sony models have a speaker on/off switch, and they can get bumped if anybody's been behind the set (cleaning or such, and sometimes a pet can get back there and bump the switch). Also, check that the TV hasn't has the SAP (second audio channel) turned on. On many Sony remotes there is a single button to select that mode, and if there isn't a SAP channel being broadcast, on many models you get no sound at all.
If you're using a satellite receiver or cable or FIOS set-top box, make sure the volume is up on that device. They often have volume control separate from the TV, and you may have turned the source volume down.
You didn't give any information about what you have connected and whether the sound trouble is on all sources, so I can't tell you too much more. Make sure all your cables are properly connected (they sometimes work loose) and all audio sources are working properly. If the sound still is missing after you've checked what I suggest, you should to have the TV checked by a service technician. There are many possible electronic causes for the sound to quit, but nothing you'll be able to track down and repair without the proper tools, information and experience.
Good luck, and thanks for using Fixya!
Posted on Oct 17, 2010
How to reset the parential controle on a sony trinitron wega KV-27fs120
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock to many popular brand TVs are given.
Jan 07, 2015 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony WEGA KV-27FS120 connected to LG BP200
What is the problem you faces when connecting this TV with LG Blu-Ray player?
Jan 19, 2013 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My sony trintron is stuck in stand by mode
If model number listed here (kv-27fs120) is correct the set if not coming on is in shutdown because either a problem in its power supply or something elsewhere pulling the supply voltages down and triggering shut down.
Someone would have to open and first check for voltages and or shorts--no real other easy way to troubleshoot this.
Mar 19, 2012 | Sony FD Trinitron WEGA KV-27FS120 27" TV
SONY TV MODEL KV-27FS120 stand by light
if it is continous blinking.........then you have a faulty jungle IC IC301,shorted to ground,IK video path is defected,............ hope this helped
Feb 17, 2010 | Sony Televison & Video
Sony KV-27S42 no sound and audio blinks four times
+13 & -13 requires for Vertical Deflection IC and produced by Flyback Transformer, these volts will be produced IF Horizontal deflection circuit works properly. so try to check H-Out Transistor and its necessary volts / signal. Pls also mention correct Model Number to provide you more help.
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Wega KV-27FS120
This may be a power supply, and or a high voltage, or a scan ampplifier failure. The set would have to be properly trouble shooted by an experienced TV tech to determine the exact failure. This is not something you can fix yourself at home.
Jerry G.
Apr 15, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony trinitron 29 inch kv j29mn
Possibly dry solder joints or faulty coupling capacitors around the audio section.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
KV-27FS12
hi there, there is a problem at your power supply section. do some test, it maybe a electronic part faillure. ty
Dec 28, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
