Question about Husqvarna Chain Saw 18" 450 Model 966955438
Gas trigger jams and does not depress fully on a husqvarna 345. The unit is 9yrs. old.
  • Husqvarna Master
  • 2,239 Answers
Check for wear on the plastic end of the throttle push rod, if so it tends to catch where it comes out of the fuel tank, replace if worn.
Posted on Jan 14, 2011
I have a Husqvarna 435.Hard to start.When it runs, it has no power.It does the same as if it runs out of gas.I loosen the gas tank plug, then it starts and I'm good for 10 minutes.I also have a Husqvarna...
Sounds like the fuel cap on the 435 is not venting properly. Change the fuel cap and do not overtighten. Should correct your issue. The 435 is a nice light weight unit.
Feb 14, 2014 | Husqvarna Garden
Trigger wire that goes to the carb is not working. what can i do to fix it?
There should be a safety bad on ths handle that you hold down so that you can pull the throttle trigger. Check to make sure you are depressing it enough or that it is actually unlocking when depressed.
Sep 08, 2013 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Unable to locate adjustment control for chain oiler model 345 husqvarna chainsaw
Not all 345 machines had an adjustable oiler, it is retro fittable if it does not, however if it hs an adjuster, the screw is located on the bottom of the saw between the cranckcase and the fuel tank, just below the sprocket, there will be an oil symbol and a - and + sign there, the pump is three position, for 13/15/18" bars.
Oct 02, 2011 | Husqvarna Forest & Garden No.967012396 345...
Trimmer does not run at full speed when trigger is fully depressed
Could be an air leak within the system, check fuel lines and carb gaskets. May be a fuel starvation issue, check carb settings and possibly clean and service if required
Sep 19, 2011 | Husqvarna Garden
Pull the trigger, no nail, only continuos air until I release tyhe trigger. not jammed, gun is clean, very new. acted that way right out of the box then it worked and then not and so on, worked...
Safety foot and lever inside of trigger are not pushing the trigger pin all the way in. To verifty that the gun will fire, remove the nails to allow for dry fire. Remove the trigger to reveal the trigger valve. Hold the gun against old coiled rubber hose or soft wood. Very quickly depress the trigger pin all the way in. If the gun fires, adjust safety foot and trigger so that the trigger pin is fully depressed when your bump fire. If the gun will not fire after adjustment, remove the head and lube headvalve/orings with silicone paste lube.
Sep 03, 2011 | Stanley Bostitch Mcn150 Strapshot Metal...
I have a husqvarna model 50 chain saw and am not sure of the ratio of the oil & gas mixture.
Husqvarna Rancher 50 1982-11 OM Follows:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS1982/HOUS1982_O8200003.PDF
50:1 according to your manual if using Husqvarna (quality) 2-cycle oil.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 01, 2010 | Husqvarna Forest & Garden No.967012396 345...
I can not find the serial number on my 345 husqvarna chain saw. wher do i need to look?
Page 6, item 1
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_1150986-95.pdf
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
HTH
Lou
Jan 21, 2010 | Husqvarna Forest & Garden No.967012396 345...
Is there a hose that attaches to gas tank vent on husqvarna 345 e chainsaw
You can find an answer to your question here:
HusqvarnaUSA.com
Uncheck "Manuals" check "Illustrated parts lists"
I think your answer is on detail "J"
pns 503 60 04-01 and 501 62 98-01.
All fuel system components can be found on these illustrations. I wish Husqvarna included nomenclatures but they don't. Your local Husky may be able to verify by telephone these are indeed your fuel vent.
Serial number decode – for use with IPL
06 1500198
It might be a good idea to save a copy of both your Manual and the IPL to your computer. HTH
Lou
Nov 08, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna Chain Saw 18" 450 Model 966955438 Logo
93 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
