Lanier lp226cn printer
Lanier lp226cn error code sc545 printer won't work, maybe a fuser error? new and has not been used enough for this to happen!!! Can I re-set this?
2 Suggested Answers
drichards
  • 87 Answers
SOURCE: Lanier lp226cn
Hold the up and down arrows together for 10 seconds, and press ok. Select 2, for engine. Scroll to 7 or data log, press ok. Scroll to 7807, press ok, execute, exit all the way back to engine, and select 3 to end. Turn printer off and on. Try it. It is a fuser code, and it just might be dirty where the sensor touches.
Posted on Jun 07, 2008
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
SC545 error message on my Lanier LP226c - anything I can do
Its a fuser Temp error. Check the thermistors on the fuser make sure they are good
Mar 23, 2010 | Gestetner DSm515pfd Digital Copier -...
My Lanier Super G3 is telling me the service code is SC545. Could you tell me what my problem is?
It's a fuser warm up error. Can only be reset in service mode by a technician after problem is repaired.
Apr 17, 2009 | Office Equipment & Supplies
Error code sc545
That's a fuser warm up error. Likely either a blown fuse, lamp or thermistor. Fuser is usually replaced as an assembly, and code can only be reset in "service mode" after the cause is fixed.
Mar 14, 2009 | Ricoh Aficio CL7000 Laser Printer
Jun 03, 2008 | Office Equipment & Supplies
Ricoh c410dn sc307
That crosses over to the Lanier LP226cn.
SC307 - Charge AC bias error [Y] (Level D Error)**
Symptom: The charge current less than 200 ìA is detected.
Possible Causes / Required Actions:
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power 1
1. Check the connectors.
2. Replace the PCU for yellow.
3. Replace the drum positioning plate.
4. Replace the high voltage power 1.
** (Level D Reset Procedure) Turning the main switch off then on resets SCs displayed on the operation panel. These are redisplayed if the error occurs again.
- Lanier Tech
May 21, 2008 | Office Equipment & Supplies
145 people viewed this question
jasbo
jasbo
