Question about Lakewood 16" Stand Fan
The fan motor does not working after turn ON - Lakewood 16" Stand Fan
My 900 em do oven keeps over heating and switching off
follow thes steps and fix it.God bless you
Exhaust Fan Motor
If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it doesn't, replace it.
Thermostat
If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board
If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.1_24_2013_5_50_54_pm.gif1_24_2013_5_53_00_pm.jpg
Jan 24, 2013 | Microwave Ovens
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
Fan stopped working
Try to turn the fan by use of a long screw driver or other object. If it feels like it is siezed or getting very hard to move then the fan motor needs replaced. If it turns freely I would replace the capacitor and if that does not solve it then replace the fan motor too! Capacitors are cheap and fan motors are $80 to $120 average!
Jul 08, 2010 | Weather King 10AJA4201AH Air Conditioner
A/c works great when fan is on high speed when
Could be as easy as a new blower motor switch or blower motor resistors.
Apr 16, 2010 | 1995 Nissan Pickup
The fan blades do not turn but the fan motor can
speed switch is no good, the one attached to the pull cord. replace
Jul 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Blades will not turn
The motor probally damaged while you are moving the fan to the new house.
Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
Fan not working
Hi, its likely that the fan motor isn't working. (most times is just build up of grease) If you're good with DIY, remove the inside panel that covers the element and the fan, undo he nut CLOCKWISE, pull the oven out, remove the the back cover, remove wiring from fan motor, clean the motor with WD40, and give it a few turns to see if turns freely. Reserve the process.
Cheers
Feb 07, 2009 | Zanussi ZBF360 Electric Single Oven
1992caravan turn signals, low beams, and heater motor do notwork
A) Faulty turn signal switch or circuit.
B) Broken dimmer switch or poor electrical connection.Could be relay also.
C) Unplug the electrical connector at the motor and use fused jumper wires to connect the fan motor directly to the battery. If the fan still doesn't work replace the motor. If fan works could be your relay.
Jan 19, 2009 | 1992 Dodge Caravan
Fan motor does not turn
FIRSTLY HOW MANY WIRES ARE COMING OUT THE FAN MOTOR AND WHAT COLOUR DO YOU GUYS USE AS LIVE AND NETURAL IN YOUR COUNTRY.
MOHAMED
Sep 19, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Lakewood 16" Stand Fan Logo
41 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
