Question about LG LFX25960ST Stainless Steel French Door Refrigerator
The control panel light blinking and ice trap door will not close
Unprovoked light blinking, ticking sound, ice trap door will not close, control panel gone hay wire. If the unit is not completely shut down a fire hazard. The unit is not even two years old.
    Problem Solver:
  • 13 Answers
If this is like our LG refrigerator, the control panel is just a dumb display and switches, and the actual microprocessor controlling everything is on another board. The lights on the display may actually be used as a status indicator of what is wrong. The decode of these light may be on the schematic of the refrigerator, which may be in an envelope behind the front kick plate, behind a removable back plate, or under a cover on top of the refrigerator.
Posted on Nov 06, 2011
    Champion:
  • 210 Answers
Sounds like you need a new display pwb. The flapper for the ice works on a solenoid which is on a little board that is behind the display board. When the power is cut the flapper should close as it is on a spring. I don't believe that there is any worries of it catching fire. Have a tech come and replace the board for you.
Sgt 48
Posted on Jun 04, 2008
Tip
Appliance Repair Boise - Maytag Refrigerator Lights Blinking, making Clicking...
If your Maytag Refrigerator has the above symptoms, you may also see the dispensor ice door opening and closing, then your control board is likely bad. The control board is located on the back of refrigerator under a panel. Be sure to follow the instructions that come with the new mother board. There may be some re-programming that is necessary.
Rich
on Oct 12, 2010 | Refrigerators
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
The Control Panel/Dispenser light went crazy...
Sounds like a electronics problem would need to replace the board, LG parts are not normally expensive.
Apr 11, 2010 | LG LFX25960ST Stainless Steel French Door...
The ice trap door won't stop cycling open and closed and the control panel on the door is blinking all of the lights
Called maytag with model and serial number. This is a very common problem. They sent a new mother board free of charge within a couple of days. You will have to go to the back of the fridge to swap mother boards. It was pretty simple if you have a little patience. Maytag wanted to charge $200 for the service call but it took my husband about twenty minutes. Then you will need to reprogram with the code inside of the door. I was told that this happens alot if there is a power surge, so I now have the fridge on a surge protector. Haven't had a problem since. Hope this helps.
Nov 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
When the light switch in the freezer goes out (by me holding the the switch in or by closing the door) there is a noise that comes from the ice maker. Turn the light on, it stops. Any ideas? The noise is a...
The door switch is designed to turn off the dispenser control when the door is open and the light comes on. Pressing the switch with the door open turns on the dispenser controls and the sounds of relays and solenoid coils would be normal unless it is affecting your dispenser or ice maker. Thanks, Sea Breeze
Sep 30, 2009 | Maytag MSD2651 HE Side by Side...
ICEMAKER FROSTING UP
Try to take some ice from the dispenser. Remove the glass and open the freezer door to look down inside the dispenser chute and see if the trap door has re-closed. If it remains open warm, humid air will enter the ice bucket and gradually freeze the cubes together. Trap door remaining open is generally caused by a rusted electrical coil which pulls the door open electrically then sticks, unable to re-close. Coil is located behind the panel that operates the dispenser. Relatively easily accessible.
Jul 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Main control board in the back failed. Maytag was covering all these with their name on them. I dont think sears is past the 1 year warranty. Was a defect from Maytag, new board is redesigned...
Jul 14, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag MF12568AEB refrigerator
the high voltage control board is bad. located on rear of machine.
Feb 15, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
No water or ice through door
sounds like the dispenser assembly is not sensing that the trap door is opening fully, so it wont send power to the auger motor or fill valve. If you are pretty handy, you can disassemble the door and take out the dispenser assembly and try to take the assembly apart and correct the throw on the trap door. Otherwise, I'm afraid you need a new dispenser to the tune of about $250 parts and $225 trip and labor. Good luck!
Nov 07, 2006 | Sub-Zero 690 Side by Side Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
463 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
