Question about Nikon D40x Digital Camera
When I look through the viewfinder on my Nikon D40x it is blurry and looks out of focus, but when but after I take the picture it is clear on the lcd screen. Is there a setting I can change or is something wrong with my camera
  • 10,594 Answers
Adjust view finder focus as you will see setting there, to view correct focus in view finder itself.
Camera is just fine because it is taking good focus pictures.
Posted on Oct 17, 2010
I have just purchased a Nikon D60 and the viewfinder eyepiece always appear blurry prior to taking a photograph. Yet, when I take the picture it is clear and sharp so the picture is in focus, but prior to...
There's a diopter adjustment control near the right edge of the viewfinder. Look through the viewfinder at a blank wall and adjust this until the focus marks appear sharp.
Jul 20, 2011 | Nikon D60 Digital Camera
Problem with viewfinder - focus?! I've been using my Nikon d3000 for over a year now. Few days ago I tried to take a photo but when looking through the viewfinder, the photo wasn't focused. It was...
There's a diopter control near the viewfinder to adjust the viewfinder to your eye. Try adjusting that while peering into the viewfinder and try to get the focus brackets and the data at the bottom of the viewfinder into focus.
Jun 20, 2011 | Nikon D3000 Digital Camera
Can I use the LCD monitor (rather than the viewfinder) when taking pictures ? If so, how do I set the camera to do this?
No, you can't. Nikon didn't introduce the "LiveView" capability in their dSLRs until the D3 and D300. The older D40x requires you to use the viewfinder.
Jan 10, 2011 | Nikon D40x Digital Camera
I have a Nikon D40x digital camera. The problem began when the screen began showing some type of diagram over the picture I had just taken. The camera then started having difficulty with auto focus. ...
Seems possible that the servo control /main processor control is faulty and will need help from Nikon service , It will be better to get a evaluation for the fault and so we can have a consenses on the fault.
get estimate and decide.
Sep 28, 2010 | Nikon D40x Digital Camera
Nikon D80. It worked fine until recently (maybe after I took pictures during whale-watching in a heavy rain and camera got wet). Now the view in the viewfinder is kind of greyish and blurry. Focus area...
Seems like your problem on greyish/blurry viewfinder is caused by the camera getting water logged. Get your cam cleaned by Nikon.
The flashing red light usually happens if you have this indicator set in the camera. This may not necessarily be an error.. just a setting that you have put in place in your menu.
Jul 10, 2009 | Nikon D40x Digital Camera
Looking for viewfinder is blurry (Panasonic Lumix DMC FZ28)
There's a small dial on the left side of the viewfinder (next to the flash button) that allows you to focus the viewfinder. I only found it because I had the same problem - must have knocked it out of focus by accident!
Apr 07, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
40 DX - blurry pics
The lens is out of focus or the shutter speed is too slow, to determine if this is a defect or failure, mount the camera on a tripod and use the self timer or remote cable (if you have the remote cable) to take exposures while autofocusing on a neutral colored object such as a beige item,
if they're still blurry then manually focus the camera and try again.
If they are still blurry and your Nikon has a diopter focus adjuster (this is typically in the rear next to the viewfinder where you focus your eye), set the diopter to neutral and manually focus again.
If they are still blurry, remove the lens and using a cloth dampened with high percentage or denatured alcohol, clean off contact rings since this is where the lens and the camera body communicate and transfer focus data.
If they are still blurry, then use the same cleaning method for the contact ring of the camera body.
If they are still blurry use a different lens and repeat the first two steps.
If they are still blurry then you may have a smudged and dirty sensor, this is the part which actually registers the image and should be cleaned by a professional.
If you are so brave to, you can use the cameras feature to lock the mirror and expose the sensor, this is typically only done to perform a dust cleaning using light blasts of clean air and using solvents on the sensor is dangerous.
If you choose to do so anyway, use a bright flashlight and look for anything that appears to be smudging, if it isn't apparent then your camera or lenses are likely in bad need of maintenance.
Aug 23, 2008 | Nikon D40x Digital Camera
Nikon D40X, no picture on lcd when trying to take a photograph, o.k. when picture is taken.
conorp, not on a D40. This camera does not have the "Live View" capability.
Feb 28, 2008 | Nikon D40x Digital Camera
Rebel XT pictures are in focus but look blurry in viewfinder
Use the little wheel dial with the +/- sign on it right on the viewfinder...ajust it until things are clear
Nov 22, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D40x Digital Camera Logo
279 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
