Question about Memorex MVD2022 DVD Player
My memorex MVD2022 DVD player won't function. I tried several different DVD's; at first all I was getting was the DVD video screen with "loading" appearing on top, than I got it to start playing but it just played the opening warning, on another it just played the 'production' icon of DVD; then it jumped into the middle scene of a movie, it rewound x2, x4, any faster it just froze, and when I ejected and reloaded disc so I could start from begining, it never played movie again. I tried unplugging and replugging; it seemed to keep doing different things. I've had over a year, used a couple times with no problems; but its been a year since I last used it; and it says in manual "If you do not uses player for a long period, the unit may not function properly in the future." Well, thats great, so what do I do?
SOURCE: I cant get my dvd to run without the pscan split screen coming help.... follwed directions in manual it didnt work HELP memorex dvd player model#mvd2022
had the split screen with pscan triangle looked for the button on the back, no button but on the remote was a button named V.MODE pressed it and everything back to normal thanks for the help
Posted on Oct 05, 2008
  • 3 Answers
SOURCE: My Memorex DVD Recorder (MVDR 2102) won't open
Most likely one or more capacitors on the main board went bad. I just fixed one last night with the exact symptom.
Posted on Oct 09, 2008
localwonder
  • 6784 Answers
SOURCE: i need my remote to run my dvd player so i need the codes
Hi, the original remote for this unit is no longer available but, you can purchase a REPLACMENT remote on this web page i will post below.
CLICK TO PURCHASE A REPLACMENT REMOTE FOR YOUR DEVICE.
Posted on May 16, 2009
alenjogy
  • 123 Answers
SOURCE: memorex mvd2022 dvd player froze, nothing works
we want so many things to repair it.so the better way is to go to a servicing center
Posted on Jul 19, 2009
SOURCE: my memorex mvd2022 wont turn on and i have it
Regarding your problem, if the unit is plugged in and it does turn on you can try power resetting it. Leave the unit unplugged for 30 minutes and then plug it back in and turn it on. Also, try connecting the player to another outlets to make sure if the problem is with the product itself or just a bad contact with that outlet.
If still the unit does not go on, I think it is defective and you could take it to a local repair shop to have it reviewed by a technician. Hope this helps you.
Posted on May 03, 2010
Tip
Remote Control Problems
hi, BEARHOUSE IS HERE WITH THE Answer i Purchased a Memorex MVD2022 DVD Player at a Goodwill Store For $7.00 Dollars. I Had a Coby Model# 224 with Remote Control My Coby Quit Working the motor Drags. I had Both DVD Players on top of Each Other Tried The Remote For The Coby and The Memorex DVD Player Blinked. So I Cut off The Coby And What Did Find I Found that the Coby Remote Worked on the Memorex The Buttons Are Different But Works Good Enough For Me.
The Setup Button Eject the Disc and the >> fast Forward Button Turns it on and off
and the Program Button works For Sub Title other Buttons have other functions for The Memorex MVD 2022 Only thing You Have to work the sound From Surround System are TV.
on Feb 23, 2008 | Memorex MVD2022 DVD Player
Memorex mvd2022 video setup
Download the user manual by this link, and refer it.
May 29, 2012 | Memorex MVD2022 DVD Player
I have a dish network remote but cant find the universal code to program my memorex 2022 dvd player
We would be happy to help you with getting your DISH Networkremote to control your DVD player. Start by holding down the TV button located on the top of your remote until all mode buttons come on, then release. Use the number buttons to enter thecodes for your Memorex MVD2022 DVD Player; here some of the codes we currently have: 549, 554, 566, 789, 516, and 533.Press the pound (#) button after code has been entered. To check that the code works try several differentfunctions on the remote to make sure it will properly operate the DVD player. Keep inmind that some codes may not be compatible with your equipment. If this is thecase, please try the other codes listed for that device until you find one thatis compatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Aug 08, 2010 | Memorex MVD2022 DVD Player
Why does my dvd player have two pictures with PSCAN displayed across the screen?
The progressive scan it´s for high definition Tv´s and if you´ve got standard tv need to disable that function
Jul 16, 2010 | Memorex MVD2022 DVD Player
Memorex dvd player pscan split screen
I had the same problem with mine. I flipped the switch on the back and it worked instantly, hope yours does too.
Feb 26, 2009 | Memorex MVD2042 DVD Player
May 16, 2008 | Memorex MVD2022 DVD Player
Black and White Screen
For a Memorex MVD2022, it would be necessary to turn OFF the YUV. This is done by pressing Setup, Enter, Up/Down to select Video, Enter, S-Video and YUV.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 10, 2008 | Memorex MVD2022 DVD Player
Mine looks like it might have a burnt 5W33K resistor. It's the large resistor labeled 5W33KJ located on the front right corner of the main circuit board.
Jan 25, 2008 | Memorex MVD2022 DVD Player
Memorex MVD2022 DVD Player Logo
77 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
