Question about Ovens
Microwave oven The internal fuse keeps blowing on my built in microwave oven. We have replaced the magatron and door switches but it is still happening. Can you help ?
  • 413 Answers
The high voltage capacitor is probably shorted, (large, silver, oval shaped part). typically .98mfd to 1.02mfd
Posted on Jun 03, 2008
NO POWER IS GETTING TO THE MICROWAVE NO MATTER WHERE I PLUG IT IN
the internal fuse inside the microwave has blown.JUST REPLACING THE FUSE PROBABLY WONT FIX IT the fuse usually blows when one or more of the door switches is bad so fuse and door switches would be needed
if ya replace the fuse and it blows again right away it defiently is going to be a door switch that is causing it to blow
Aug 25, 2011 | Ovens
Is there a fuse or re set button on my neff combo micro wave, ive just cleaned it and now have no power to it, i have checked the fuse
ISOLATE THE MICROWAVE DO NOT OPEN AS YOU CAN RECEIVE A SHOCK FROM THE INTERNAL CIRCUITS.
Check the mains fuse in the plug, remove fuse and put into a working appliance, if it works. Buy a new microwave, as the internal circuit has a fault, and depending on model, the cost of repair is usually very expensive. Unless you have an appliance insurance. leave repairs of this type of appliance to the proffs.
Check the door is closing properly, as a switch is activated by the colsure of the door, some cheaper microwaves use plastic and this can fracture, causing the microwave to not work. The front display should light up regardless of the switch position. The fuse inside can be 10 to 15amp slow blow, if this is the case, scrap the appliance as it requires specialised equipment to fault find and carefull handeling discharging capacitors and so on. A reasonable level of knowledge of electronics is required. hope this is of assistance.
Johnf1
May 17, 2011 | Ovens
Microwave oven r-5xxx 20a fuse blows after fuse replaced nothing happens oven is dead
check door switches and before that make sure about somthing burnt like PCB /CAPASITOR /MAIN TRANSFORMER
Aug 05, 2009 | Sharp Ovens
The oven would not start
It doesn't work at all If your microwave oven doesn't seem to work at all, check these: 1)Fuses---- Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. 2)Door switch--- If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. please do not forget to rate the solution.thanks.
Jun 12, 2009 | Ovens
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Sep 19, 2008 | Ovens
KitchenAid KEMC308KSS02 Microwave Error
The micorwave oven light does not work and when I push start, the word DOOR shows on the screen and beeps 3 times. The oven will not start.
Jun 14, 2008 | KitchenAid KEMC308 Electric Double Oven
KEMC308KBL01
send me am e mail at b4829@yahoo.com with the model number
May 31, 2008 | KitchenAid Architect Series KEMC308KSS...
Microwave oven works while door is open
no there are three safety switches that control that the one that lets the magnetron run will blow the fuse if its bad you have a stuck door switch but there are recalls on some microwaves check here http://www.recalls.gov/ and here http://www.sears.com/shc/s/nb_10153_12605_NB_CSrecalls?adCell=AF or go to panasonic to find out other than that you need to replace a door switch let me know if i can be of further assistance
Mar 28, 2008 | Ovens
Service Manual
when you took down the control panel and gained acess to the upper cavity , there wasnt a service manual just to the left inside a red plastic bag???, if not there is another fuse loacted just behind the micro front looks to be atop the capacitor area
Mar 09, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
