Question about Crosley CR249TA Turntable
Platter will not turn. BSR model C1232R D6; LD4115/571. I have check the motor and it operates. I cannot get the platter off!! I have removed the stem that holds the records. What else do I do to get the platter off??
2 Suggested Answers
STYLUSCITY
  • 271 Answers
SOURCE: How do I remove the platter on my record player?
Hi, remove the disc in the centre of the platter. Under there you will find a cir clip that holds the platter in place. It may need a light tap on the spindle with a rubber hammer of piece of wood. styluscity@gmail.com
Posted on Sep 13, 2010
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    I need a service manual for the BSR McDonald CA 50 turntable
    BSR tended to make old style turntables, ones with a 78rpm speed on. I don't the model in question, but if it is a one of these, there's not much to them. Basically a rubber tyre runs inside the rim of the platter, while the tyre is pushed on a mains powered motor, in at least 3 different positions (depending on the speed). The tyre moves up and down depending which speed is selected.
    Speed faults are caused by either a bad motor, or muck, oil, or grease in it.
    A faulty tyre that is worn and doesn't push on the motor or platter anymore or not hard enough. Plus of course tyre height setting wrong.
    Nov 08, 2015 | Audio Players & Recorders
    How do i install a belt on a philips stereo turntable
    To replace a drive belt.
    Before starting unplug from mains power source.
    1, Remove the rubber platter mat to expose the platter.
    2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
    3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
    4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
    5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
    6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
    7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
    8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
    9. Replace the rubber mat and then run the turntable to ensure correct operation.
    Job done.
    Stylus City
    Sep 15, 2014 | Philips Audio Players & Recorders
    Sony PS-lx250h
    Most likely the belt has come off or is worn.
    Job done.
    Jul 02, 2014 | Sony PS-LX250H Turntable
    The belt came off my record player how do i put it back on
    take out the plate. there is a small wheel that turns and a big wheel below the plate. You should put the belt around them both and then put the plate on it (be careful, it's heavy).
    Nov 16, 2011 | Audio Players & Recorders
    How do you put on a drive belt?
    Hi Janie, Thanks for your question. To replace a drive belt.
    8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensre the belt is riding correctly.
    Job done.
    Note the new belt should sit on the platter pulley and not fall off when the platter is flipped over the correct way up.
    When changing speeds between 33 and 45 always be sure that the platter is turning to ensure proper placement and rpm.
    All the best, John. Styluscity@gmail.com.
    Oct 30, 2011 | Technics SL-BD22 Turntable
    1960s stereogram.bsr turntable turning to do fast.
    If I can understand you right, the turntable is running fast. I don't think you need a new motor, generally the deck will run slow if the motor is knackered (or not at all). What you need to do is remove the platter, you will find a horseshoe bracket holding it on at the spindle (it may be covered up so you wil have to remove the cover part often a silver disc). The most likely cause will be the rubber idler tyre being worn damaged etc or out of place. There could be grease dirt or something else causing the problem.
    Mar 25, 2010 | Audio Players & Recorders
    The record won't turn at all....maybe the motor? speakers work, radio works. needle goes over but goes right back cause record isn't spinning. (just bought it last night, so i really have no idea how to...
    check if the platter spins if you manually turn it.
    The platter is motor driven either directly (rarely), by a belt or by a rubber idler. The only way to know is to remove the platter or by model # (which is not listed on this post.)
    Check the platter and post back with the model/make in the body of your post.
    Oct 29, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
    I had to order a belt for my turntable that was disinagrated so I dont know how to put the new one on. could you please either show me a picture of how it goes on or explain
    First, remove the rubber mat (platter cover)
    Next, there should be 2 oval shaped slots in the aluminum platter.
    Carefully rotate platter until you can see the drive motor pulley through one of these slots. Lift straight upwards on platter to remove it. On the underneath side of the platter, there is a surface that is approximately half the diameter of the platter. Place the new belt around this surface, ensuring that it is not twisted.
    Fun part.....Turn the platter right side up and insert index finger through on of the oval slots. Slip belt over finger between belt and platter "pulley" surface. Carefully reinstall platter with finger/belt slot lining up with drive motor pulley. Slip belt over drive motor pulley and remove finger, making sure the belt is not twisted. Now, manually rotate the platter to check for proper belt movement.....if all is well, reinstall rubber mat (platter cover) This concludes belt installation.
    Jun 11, 2009 | Technics Audio Players & Recorders
    Belt replacement
    http://www.archive.org/details/Turntable_Belt_Installation
    above is a generic video that applies to almost all turntables including yours that will show how to install the belt an a few other things.
    Nov 08, 2008 | Aiwa PX-E860 Turntable
    Crosley CR249TA Turntable Logo
    59 people viewed this question
    Top Crosley Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Electro Med Services...
    Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
