Question about Kenmore Oasis HE 27082 Top Load Washer
While in spin cycle our washer is making this noise like metal balls clanking together. I thought maybe the washer was out of balance, but it wasn't. My husband thinks it's a bolt or a penny that's stuck in the tub wall... Anyone know what this could be?
Yes, your husband is correct, it is coins. There is a filter trap at the bottom of the tub. You can access this after removing the rear panel. My husband pulled 45 cents worth of coins out of ours. You will need to disconnect a hose and remove a couple of screws to get to it. Hope this helps. This has been just one of the many problems we have had with this machine.
Posted on Oct 18, 2010
What causes a harmonic balancer to make a clanking noise
This usually means the harmonic balancer is coming apart , it is made of two peices held together with molded rubber the rubber is probably worn
Jun 08, 2011 | Oldsmobile Cutlass Cruiser Cars & Trucks
Samsung washer WF409 is making a clanking noise at spin cycle
CHECK THE TUBS AND MAKE SURE YOU HAVE NOTHING THAT FELL OUT OF A POCKET ALSO CHECK BETWEEN THE BOOT AND TUBS.OTHERWISE CALL FOR SERVICE THATS WHAT WARRENTYS ARE FOR! GOOD LUCK!
Jan 16, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
In the spin cycle, my washers agitator spins but not the drum. Aren't they supposed to spin together? Also alot of knocking or clicking noises
yes in the spin cycle the agitator and bowl lock if not clothes ball up and machine goes out of balance check the spin coil or electric damper is activated during spin cycle if not replace if blown or open circuit also clutch arm cold be broken have a close look keep me advised
Nov 05, 2009 | Washing Machines
Grinding Noise
yes you are right the tub bearing has failed
May 21, 2009 | Estate TAWX700JQ Top Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Feb 18, 2009 | Washing Machines
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
Washer makes clunking noises.......
You didn't give to much detail about the noise, other then clunking. Does it sound like it's metal against metal? Does it sound hollow? When does the noise take place before, during or after the spin cycle.
The easiest thing to do is check to see if the motor is loose, or if you might have too much slop or slake in the belt, if you do then replace and readjust the belt.
Nov 16, 2008 | Whirlpool LTE6234D Top Load Stacked...
Maytag Top Load Washer - clanking noise when spinning
no spin cycle or agatator movement , fill cycle and pump cycle works
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
124 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
