Question about Dishwashers
Machine is not rinsing dishesclean. White build up deposits on everything, which does not even scrub off by hand! Tried a bottle of dishwasher cleaner last night with no luck.
  • bmehr9 Oct 21, 2010
    My mother told me that they had recently started experiencing the same issue with their dishwasher. She also mentioned that she had heard a story on the news about how detergent manufacturers have began to formulate their products without phosphates and that this is most likely at the root of the problem. Do you know anything about this? We live in Utah which is notorious for HARD water.
  • bmehr9 Oct 22, 2010
    Absolutely helpful! Thanks so much for the ideas and input. I think this is a very cool thing you guys got going on here. Thanks again.
    Bryan Mehr
    President:
  • 1,891 Answers
Ok i know the feeling . what this is called is hard water filming . you need a stripper like jet dry cleaner . or glass majic . this will clean up the problem. then if i knew how hard the water was i could help more . / this what you need is fresh soap ( podwer ) not licquid . and hot water in the wash 140 deg . if your machine has a heating cycle use it . turn of the heat in the dry as this makes the problem worse . and use a rinse cond in the disp or rack . .. i think these will help you ..mm cascade with dawn works best . or cascade complete .. .. mm and thank you using fix-ya
Posted on Oct 17, 2010
  • dennis dodge Oct 21, 2010
    have your heard ( ************ not wrong ) so don't use the liquids just the powder . and use heat in the wash only . do use a rinse additive . and use longer cycle to raise tank temt. i am in south jordan utah . so i know what your saying . we deal with this washability problem a lot . if you need more help i will need your brand and model and i may be able to help more . you will have to clean up the problem before the dishes start looking better . try washing with cascade w/dawn tabs and adding glass majic in the cup at same time. this works . and always use jet dry in the disp .. mm
  • dennis dodge Oct 22, 2010
    THANKS FOR THE FEED BACK . if you need more help ck back with us majic **** . and thanks again for using fix ya . dodgeappliance@comcast.net
Leaving a white film on everything
Hi, what you are currently experiencing is as a result of dishwasher detergent, combined with mineral deposits from hard water, which in yurn can leave a white film on the inside of the dishwasher.
You have to clean the dishwasher by sprinkling baking soda onto a damp cloth. Scrub the inside of the dishwasher to remove soap scum, grime and mineral deposits.
Pour 2 cups white vinegar into the bottom of your dishwasher. Turn the dishwasher on and run it on a full cycle. Stop the dishwasher halfway through the wash cycle and allow the vinegar and steam to work on the remaining mineral deposits for 20 minutes before resuming the cycle.
Open the dishwasher and dry the interior with clean, dry cloths. Keep the door propped open for 20 to 30 minutes to allow the dishwasher to dry completely.
Hope it helps....
Jun 27, 2011 | Whirlpool Dishwashers
My indesit idl40 cleans everything, but leaves a film? does not seem to rinse?
Jun 26, 2011 | Indesit Dishwashers
Dishwasher not cleaning dishes and leaves glasses with a white film
There are several causes in dishwashers that make dishes come out with film on them or something of the sort. Here they are.
1 Water temperature should be 140 degrees. Your dishwasher should have a "sani" cycle that heats up the water into that range.
2 Most dishwashers were never engineered for liquid soap. So if you are using it, go to powder soap.
3 A rinse agent is definitely a big plus
4 In some parts of America, such as Florida, lime deposits build up in the machine and accumulate onto the dishes and glasses. It's a white film. It also accumulates in the parts of the machine and logs them. If this is the case. Run white vinigar in the machine.
Empty the machine.
Turn it on.
While the machine is filling with water, (not at the very very beginning as it will drain out existing water when it is started) put a quart of vinegar in and run it. If it has lime deposits it will greatly reduce them.
5 The spray arms may be jammed with pieces of food or other debris. make sure the holes in the arms are not obstructed.
That should do it.
Best, Mark
Jan 04, 2011 | GE Adora GHDA656LSS Stainless Steel...
A crusty residue settles on glasses and cups in upper rack and is extremely difficult to get off, requiring much soaking and scrubbing in hand washing, even when everything was prewashed going in! I've...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 28, 2010 | Asko 24 in. D3250 Built-in Dishwasher
There is a white residue on my dishes when the cycle ends. I have switched soap brands and made sure the rinse aid container is filled. The residue is hard to remove, even with hand washing/scrubbing and...
heatman101
Aug 29, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Even after a wash-a white detergent residue is left.
I have a Whirlpool Gold dishwasher and had the same trouble. I found the solution. Fill the detergent dispenser to the top with Cascade Complete liquid gel - it is in a green bottle, then put a half a cup of white vinegar in the bottom of the tub before you start the dishwasher. I have tried them all and Cascade Complete Gel works best. Don't use powder. It really builds-up on my dishes and only the gel keeps the film off my dishes.
I also add Jet Dry in the rinse-aid dispenser but I have a friend who use vinegar in that too. The dishes come out sparkling clean with no film or white build-up. If they still are filmy after three washes using this method, then you may have some build-up in the dishwasher and you can put a cup or two of white vinegar in the bottom - with no detergent or dishes and wash and rinse well. That helps get rid of build-up.
Apr 01, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher is all of a sudden leaving white film
Called limescale deposits, does it have a salt reservoir? if so fill up, if not run a bottle of white distilled vinegar in with a short program
Feb 24, 2010 | GE PDW9980NSS Built-in Dishwasher
Rinse agent dispenser doesn't seem to be working
Keeping your rinse aid dispenser filled up may help, But ... By far the most common problem of white (mineral) deposits building up in a dishwasher is someone switched from a name brand to a generic, ultracheap dishwasher powder. I love store brand products and buy them all the time but when I bought an ultra cheap brand of powder detergent, within 5 loads of dishwashers the white build up showed up.
Switching back to a brand name powder like Electrosol or Cascade will really help.
The other thing you should probably do is pull the filter gear underneath the lower spray arm and clean out what ever has collected there. That is especially true is your dishwasher is making louder/different noise during the wash/rinse cycle.
Good Luck! Please report back here what you find, OK?
Apr 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher problems
Hi Bmissy,
I had the same problem with my dishwasher. In my washer the problem was caused by a buildup of water deposits throughout the machine. I increased the temperature of the water, used three bottles of "Dishwasher Magic" and now my machine is working well. I read that the rinse aid dispensers do not disperse enough of the product for extremely hard water, the solid rinse aid dispensers work better. I know that adding a little water softener to your washer when you run it can help. If you can't find "Dishwasher Magic", you might want to try running your dishwasher with a few quarts of white vinegar to remove the deposits on the coil. You may need to clean out the deposits in your washer regularly to keep the machine working well.
HTH!
Ann
Nov 02, 2007 | Dishwashers
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
Owen Barnes
